Time to change the oil. My Z is burning a little oil. Is there any harm in putting 10W-40 in it? My thought is a little heavier oil will fill the gaps and slow the oil loss. Also, it doesn't look like I'm going to make it the SGC weekend this year. Inlaws are in town. At least I'll give them a ride in the red rocket and show them what a 15 year old car can do! Thanks in advance
![]() Join Date: Dec 2003
Yes in fact I wouldn't put 5w oil in. It's too light.
ZR-1 Mom Founder ZR-1 Net Registry Founder ZR-1 Net NCM Lifetime Member |
![]() Join Date: Dec 2004
Just two cents from a rookie owner. Are you sure it is using the oil & not leaking it. Only reason I ask is that I just had to go under the plenum and was horrified to see how loose the breather box cover bolts were on mine. What a mess it made. It was so bad that I was getting oil from the valley drain tube exit staining my oil pan in that corner!
Sorry to butt in with my lack of experience. ![]() ![]() ![]() Tom btw, I use Mobil 1 full syn. 10w-30 before & after. ![]()
