Old 10-25-2009   #1
Aurora40
Aurora40's Avatar
Default Alternative for spare tire
My spare is 18 years old now, and I've used it a couple times in the past few years. So I'm concerned about the age. I also suspect it won't clear the front brakes anymore.
To that end, I considered a GTO spare, but they are shorter overall than ours. I have heard the wheels fit up fine though.
For 2008, the CTS went to a RWD bolt pattern, 5x4.75", like the 'vette. So I figured that would fit too. The wheel is an 18" aluminum wheel, but the overall tire height is the same as ours. Plus, the spokes flare way out, giving maximum brake room.
I found a CTS spare kit new, tire not mounted, locally for $100 (they are $275+ from GM and backordered). So I jumped on it.
It has a narrower hub apparently than the 'vette. So no dice so far. I'll see if I can make it work. It looks like it would easily clear the Baer brakes, though.
Also, the wheel was surprisingly heavy for a 4" wide aluminum wheel. And it's made in China!
Old 10-25-2009   #2
Default Re: Alternative for spare tire
Any thought on getting our OEM spare hubs reskinned? Has anybody done that yet here? GC
Old 10-26-2009   #3
Aurora40
Aurora40's Avatar
Goodyear stopped making the tire about 10 years ago. There are no other radial spare tires in that size that I have found.
Old 10-26-2009   #4
ZR1Vette
ZR1Vette's Avatar
What is the tire size?
Old 10-26-2009   #5
Aurora40
Aurora40's Avatar
The CTS spare is a T135/70-R18. The Z's is a T155/70-R17.
A GTO spare, who's wheel does fit, is I believe T145/70-R17. But that's something like 3/4" shorter than stock. I would be concerned about the diff with a tire that much shorter if the rear had a flat. I've heard that can be bad for the limited slip. Though maybe it's not a problem. I also don't know if it would clear my brakes. They are also 4-5 years old now, though that's not nearly as bad as 18+.
Old 10-26-2009   #6
xlr8nflorida
xlr8nflorida's Avatar
Also, the wheel was surprisingly heavy for a 4" wide aluminum wheel. And it's made in China![/quote]
OMG, a cheap rim from China? I thought you didn't like cheap rims from China?
I bet it falls off within 2 miles
Old 10-27-2009   #7
I haven't given the spare much thought except for checking the PSI once a yr.
Bob, good point about our stuff being 20 yrs old, if you have a 90. To that end I have a couple of thoughts.
Our spare is obviously not in direct sunlight, and is usually in the garage with the car, so there are no wild temp swings or UV light. Don't we need environmental factors to degrade the rubber?
Sorry, I am just curious as my spare looks fine after I clean the dust from it. I can't see any cracks, and I haven't seen any cracks the few times it has been on the car under actual load. It looks pretty funny on the rear though!
Sorry for all the Q's! If the front tires fit in the carrier, why can't we use a front tire as a replacement for the spare?
Old 10-27-2009   #8
ZR1Vette
ZR1Vette's Avatar
I have the same concern...my spare looks perfect but being 20 years old is an issue with me. Deterioration... UV is one cause but ozone in the air is another cause...so low mileage garage kept cars will make no diff...now place in a vacuum sealed bubble you be OK
Old 10-27-2009   #9
xlr8nflorida
The majority of Foose and Boyd Coddington are made in China.
I bet it falls off within 2 miles [/quote]
Old 10-27-2009   #10
xlr8nflorida
The majority of Foose and Boyd Coddington wheels are made in China.
I bet your spare falls off within 2 miles
