Old 10-24-2009   #1
Hammer
Hammer's Avatar
Talking VSS (Vehicle Speed Sensor)
Is this the VSS that people are talking about on the listserver? It goes in the side of the transmission. Sounds like it's a part that should go in the box of spares. NLA from GM or Delco. Marc says they can leak or just not work.
Old 10-24-2009   #2
Default Re: VSS (Vehicle Speed Sensor)
That looks different than the one my 90 has. I didn't notice the mounting brkt(?) on mine, or maybe I just can't see, or maybe I was looking at what I thought was my VSS and it wasn't the VSS.
Mine, if I was actually looking at my VSS, looks like a small can with a female plug. I know the ones for the 90's have been NLA for a long time.
Old 10-26-2009   #3
Yes, and some folks bought out the entire stock that was left on Rock Auto after that email went out a few days ago.
Old 10-26-2009   #4
bdw18_123
Are the ZF6 VSS's different from the automatic ones? Cus my ZF6 VSS in the '93 I had looked different. Was bigger and had a green gear on the end that the transmission drives. Got one brand new from Autozone a year or so ago, had no problems getting it. Don't remember the brand.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 10-26-2009   #5
It looks like this is only an issue with the 90 ZR-1s according to this email and the ZR-1 parts listing. I hope someone will chime in that knows if we don't need this specific part number and why:
> -----Original Message-----
> From: Brent Craig <blcraig@EARTHLINK.NET>
> Date: Sat, 24 Oct 2009 10:53:38
> To: <ZR1NET@LISTSERV.CORVETTEMUSEUM.COM>
> Subject: Re: [ZR1] TECH: VSS
> I just had the same problem with my VSS going bad. After an
> exhaustive search, I found what could be the last lot of aftermarket
> direct replacements. Since this is also a discontinued part, the
> manufacture took down all application information (which parts sellers
> use). I accidently stumbled upon an old website with the application
> info; even after calling tech support at the manufacturer, it took
> them a lot of time to find the information in their archives, but the
> finally were able to confirm their part number as a direct
> replacement. So, here is the scoop (don't know how many they still
> have in stock, but I predict they will be wiped out after I hit the
> "send" key on this email:
> Application: '89-'90 with build sheet spec code "D9B"
> Original GM p/n: 25007308 (discontinued)
> AC Delco p/n: 213-223 (also discontinued)
> Standard Motor Products p/n: SC8
> Where avail: rockauto.com (still avail. as of 1 week ago. note - just
> type in this p/n as you won't find it in their application finder
> program)
> Now, here is the best part:
> Price: $33.99 ("wholesaler close-out)
> Perfect fit & function, and it even is visually identical (black
> housing vs. white for the later model year's sensor) for anybody who
> is anal about these things (like me).
> P.S. I already bought myself enuf extras to last my lifetime, so let
> the parts hoarding feeding frenzy begin...........
> Brent
> '90 Red/Red
> Member # #149
Old 10-26-2009   #6
Anybody think of calling Bill the ZFDoc. Im sure he know what one looks like.
Old 10-26-2009   #7
bdw18_123
The device pictured at the top is definitely not a VSS. I just looked at the one on my '90 Z, looks nothing like that. Looks the same as the one in my '93 I used to have. This is what the VSS looks like for the ZR-1's and the standard coupes with the ZF6, picture taken from kragen.com & does not show the gear that goes on the shaft (I don't know if the automatics are the same or not):
Apparently there are 2 different types of VSS, D9A & D9B (I also saw a D9E listed on Autozone.com, but it was listed as unavailable). I think the codes denote the number of teeth on the gear that goes on the sensor. One of those codes will be listed in the RPO code list under your console lid. My '90 Z has D9B. You can get a D9A from autozone, kragen has D9A's and D9B's. They aren't cheap though.
1993 Corvette Coupe
Old 10-26-2009   #8
Thanks for the research and sharing. Good to know they are at least available and I'm glad I bought mine from Rock Auto before they were all bought out; I guess those were wholesale prices they had.
Old 10-26-2009   #9
Pete
Pete's Avatar
This looks like a crank sensor,not a VSS.
If it is a VSS it looks like a 4L80E trans speed sensor.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-26-2009   #10
limey
Not sure where all this miss information comes from sometimes, but the VSS for the 1990 is available. If by some miracle, all GM dealers are now sold out, just pop into your local advance auto parts store and order part # S8048 which is the same part VSS
The correct part GM # is 25007224
Part number that is been referenced here as 25007308 is discontinued as is different in the fact it contains the VSS AND the gear, whereas part # 25007224 contains ONLY the VSS and NOT the plastic drive gear.
Just order part #
25007224 and switch out your old plastic drive gear when removing.
The 91-95 cars are different connectors and are less than half price of the 1990
limey is offline   Reply With Quote
