Old 10-18-2009   #1
DaveK
Default Watson header install advice
Hi everyone
Just picked up some Watson long tube headers from ebay and looking for advice on what I need to fit them. I have a Haibeck chip at the moment for the stock exhaust so I think I need a different tune when I install the watsons.
The headers have no cats as they come and are 3 inch collectors. My current exhaust is a borla. I'd prefer to run cats, so I'm thinking an aftermarket cat might work to match up to the rest of the system?
I imagine there will be some element of fabrication needed and between us chickens my welding isn't the neatest!
Is there anything else I should do while I'm doing this? Xpipe and so on? Advice from anyone who has done this sort of thing would be great.
Thanks
Dave
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 10-18-2009   #2
Kb7tif
Default Re: Watson header install advice
Installing the headers are not that bad just take your time. I dont think there pre-fabbed pipes you will need between the collectors and cats/exhaust so custom might be the way of life here.
I just put watsons on m y 92 and it will be well worth the effort.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 10-18-2009   #3
You will need some O2 extender hanrnesses and you will need to remove the inner fenders to free up some room for the install. I suggest you buy an oil dipstick seal from Jerrys gaskets as you will need to reposition the dip stick tube. (I'll assume you have the gaskets for the headers as well). Once pulled the large seal become brittle and can tear. As to aftermarket Cats most favor either the high flowing mdipstick tube agnaflows or the random technolgies cats.
http://www.jerrysgaskets.com/
Another suggestion may be the anti-vibration lock thread types of bolts so the bolts dont back out.
Old 10-19-2009   #4
DaveK
I have the dipstick seal from the group buy but no header gaskets - just checked Gerry's site and he has them so I'll get those ordered. Where do I get the O2 extenders from?
davidmkelly.com
Old 10-19-2009   #5
tf95ZR1
tf95ZR1's Avatar
Try:
Marc Haibeck http://www.zr1specialist.com/
Jeff Flint http://www.pnwzr1.com/, and
Randy Woods http://www.zr1products.com/
And I highly recommend swapping out the Borla resonator
for an "X" pipe. More resonance around 1800 rpm but well worth it.
Old 10-19-2009   #6
Hammer
Hammer's Avatar
Talking Re: Watson header install advice
Go to NAPA, they had the parts and I just made mine. You need to ask for Weatherall connectors if I remember right. Take the right O2 sensor with you so you get the right parts. One male end and one female end. I only needed one for the passenger side.
Old 10-21-2009   #7
IowaZR-1
IowaZR-1's Avatar
Send them to me for a "test" fit on my '93......will advise of any trouble installing.......if they don't fit I'll give you $500.
IowaZR-1 is offline   Reply With Quote
Old 10-21-2009   #8
DaveK
Thanks for the tips everyone. I did a search on the forum too (should have done that first!) and found a lot of information etc. Couple of things I couldn't find though.
1. Random Technologies Cat part No.
2. What's the best source for an x-pipe (again a part no would be useful)
Emailed Marc Haibeck, he has a dipstick adapter bracket and the O2 sensor extensions and I will get a new calibration from him to take in to account the headers.
I also found a company in ontario that does ceramic plating. Emailed them to check about getting that done possibly - no response so far. How much difference does the ceramic make? (it certainly looks very pretty)
thanks again
Dave
davidmkelly.com
Old 10-21-2009   #9
Jeffvette
Dave, order the magnaflow cats, they are cheaper and I suspect the same part as the RT units, minus the price.
X-pipe are you running a 3" system?
Old 10-21-2009   #10
DaveK
Jeff, thanks for the heads up on the Magnaflow/RT cat issue.
The watsons are a 3 inch collector. The rest of my system is a borla which is 2 1/2 I believe. From other posts on here it seems I will need to use an adapter after the cats so I would need a 2 1/2 x-pipe I think.
davidmkelly.com
