06-28-2019 | #31 |
Re: Ruff Idle ,Huge Loss of Power
On another note , is there a trick to getting plugs out of an LT5 ? I tried 2 that were easily accessible and had no luck . Maybe my old arthritic hands have lost there old man strength lol .
Mike |
06-28-2019 | #32 |
try a 1/2" set up with a breaker bar.
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
06-28-2019 | #33 |
Agree but is there an off chance that the larger wrench would break the plug off ? That was my concern . Not used to working on this beast as I only work on small car engines and motorcycles mostly and did not expect these plugs to be as tight as they are . Yikes .
Thanks for the tip. Mike |
06-28-2019 | #34 | |
I myself, if concerned, might vacuum the plug hole as much as possible and blow out with compressed air, spray WD40, let it soak overnight and loosen. However, WD40 in the hole can lead to dirt flowing into the combustion chamber when the plug is removed. |
06-28-2019 | #35 | |
Second one is Phil's modified serviceable fuel pressure regulator. Maybe someone with a good used one will chime in. |
06-28-2019 | #36 |
06-28-2019 | #37 |
Thanks for the replies secondchance .
Mike |
06-28-2019 | #38 | |
I use this setup for the #8 plug, a straight extra long extension works for the rest. Notice that the spark plug socket has the universal built in. When unseating a plug I use a quick snap of force against the ratchet handle to get them unseated. Paul rightly points out that if you do a fuel pressure test, not looking so much actual pressure, but if the fuel pressure bleeds off quickly when the pumps shut down, that’s another indicator that the pressure regulator is bad. H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. Last edited by Ccmano; 07-14-2020 at 11:53 AM. |
06-28-2019 | #39 | |
Pics of plugs from front of engine to firewall. Sent from my ASUS_X00PD using Tapatalk |
06-28-2019 | #40 |
Also picked this wobble extension set up for $11 canuck. Usually $70 .
Sent from my ASUS_X00PD using Tapatalk Last edited by Tripler; 06-28-2019 at 03:36 PM. |
