View Poll Results: Which oil filter do you use?
AC Delco 68 27.42%
Amsoil 1 0.40%
Baldwin 0 0%
Bosch 66 26.61%
Fram 13 5.24%
K&N 12 4.84%
Mobil 1 54 21.77%
Napa 12 4.84%
Penske 0 0%
Pennzoil 1 0.40%
PowerFlo 1 0.40%
ProLine 0 0%
Purolator 3 1.21%
Quaker State 0 0%
STP 0 0%
Wix 17 6.85%
Voters: 248. You may not vote on this poll
Old 10-17-2009   #31
ZRXMAX
ZRXMAX's Avatar
Default Re: Which oil filter do you use?
On a related subject.... I see Mobil 1 is $21 a jug at Wallmart... not bad for 5 quarts.
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black
ZRXMAX is offline   Reply With Quote
Old 10-30-2009   #32
Ya but......WalMart does not have Mobile 1 filters
Old 10-31-2009   #33
ZRXMAX
ZRXMAX's Avatar
YA BUT... You don't need a Mobil 1 filter... I use the Bosch... Autozone carries them.
BTW... Walmart is over $2 a quart cheaper for Mobil 1 oil than Autozone
Old 09-06-2011   #34
Chad N Swartz
Chad N Swartz's Avatar
I read on Marc's site the Bosch drains thru the check valve after 24 hrs, so I'm gonna try the Wix from NAPA
[FONT=Arial Black]#1679 in '91[/FONT]
Chad N Swartz is offline   Reply With Quote
Old 09-06-2011   #35
PhillipsLT5
PhillipsLT5's Avatar
Thats new updated Marc info
Old 09-19-2011   #36
Dime
The previous owner used Bosch and that's what I'm going to continue to use. No rattle from what I can tell, pressure comes up quickly, oil stays clean.
I've only owned the car for about two months so my opinion doesn't really matter.
[B][U]1991 No. 519[/U][/B]
Dime is offline   Reply With Quote
Old 09-19-2011   #37
bobbyhi
bobbyhi's Avatar
I will be switching from the Bosch to the WIX (NAPA) per Marc's new recommendation.....
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 09-19-2011   #38
Gunny
Gunny's Avatar
I've been using the Bosch for several years, but I've noticed more chain rattle with the last 2-3 ... Marc's new info just confirms this. Makes me wonder if Bosch has "changed" their filters. Shame, I liked the look of the Bosch with the label removed. I will be trying alternatives soon ... may even change to another filter in the next few days even tho I changed oil/filter a couple of weeks ago. This last Bosch filter has more chain rattle than any filter I've used.
George
George Jones
Founding Member #14
www.zrwon.com
Old 04-22-2012   #39
scottfab
scottfab's Avatar
Mine is not even shown. Valvoline oil filt.
But I also have some Frams.
Scott
Old 04-22-2012   #40
USAFPILOT
USAFPILOT's Avatar
I use Mobil 1 Extended performance and the Mobil 1 Filter that goes with it. No chain rattle or weird oil pressure readings on my 54000 mile LT5. I get it all at advance auto parts which normally does a deal on the mobil1 which gives you 5 quarts and a filter. I buy two kits each time and have some extra filters. Each time I also have an extra quart, so pretty soon I'll have enough quarts and filters to do it for nothing, sort of.
