Old 01-13-2012   #11
RHanselman
RHanselman's Avatar
Default Re: #99 arrived...
Originally Posted by Pete View Post
Last time i had a set of those cams i don't know if they were EA22B or EA22H which ever ones i had i did check them.
The ones i had were .230 pri .240 sec on the lift i will have to double check my files can't remember right now what comes to mind is .400pri 420sec again i will have to double check.
Pete
Copy, Do you think these equate to Stage I or II CAMs?
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 01-13-2012   #12
RHanselman
RHanselman's Avatar
Don't ask me the details because I don't know... But here's the Dyno Sheet
Old 01-15-2012   #13
4-cam
I may be interested in the B & B. I Need to get rid of my Borla also. Let me know what you want.
[I]4-cam[/I]
[I]1991 ZR-1 Blk/Gry #31[/I]
[I]SW Headers/Xpipe- Dynomax Muffs[/I]
[I]Ported top end[/I]
[I]Secondaries Removed[/I]
Tune by Dominic
4-cam is offline   Reply With Quote
Old 01-15-2012   #14
Pete
Pete's Avatar
Ron,if were talking for intake cams,here's what i think.
Since we know the specs of Stage I cams .228 .415 and
Stage II .237 .440
If you did an average between primary .230 & secondary .240 i would say they're closer to Stage II intake cams.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-18-2012   #15
scholtmj
scholtmj's Avatar
Stage II .237 .440
Pete
Can you regrind stock cams to EA22H specs or do you need new blanks?
Can we get a video of #99 sounds!
Old 01-18-2012   #16
Pete
Pete's Avatar
Yes, could be done, will need to pay for master.
If somebody has an old EA22H laying around even if some of the lobes are wiped out,send it to me to spec it,will send it back to you.
Also checked my records the lifts for the one that i had was .430pri .430sec
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
