07-16-2020 | #101 |
Re: Ruff Idle ,Huge Loss of Power
07-16-2020 | #102 |
Well I knew it . I finally found the LAGFF DVD set ... Hidden in an old briefcase .
07-16-2020 | #103 |
I'm interested in hearing the engine to determine if all 8 cylinders are firing.
Did you verify that each HI-TENSION lead is providing a signal to its matching plug? For example, if one coil is failing, 2 cylinders will go off-line. Did you verify that each primary injector is getting a (-) signal from the ECM? One failing or partially failing injector or (-) signal to an injector will be very noticeable at low RPMs. |
07-17-2020 | #104 | |
Lots to learn with these beasts indeed Thanks Mike Sent from my SM-A205W using Tapatalk Last edited by Tripler; 07-17-2020 at 08:27 AM. |
07-17-2020 | #105 |
https://www.youtube.com/watch?v=fEXF...ature=youtu.be
When the tac reaches 2500/2700 rpm the engine surges to 3000 https://www.youtube.com/watch?v=io-9ucGfg4I Last edited by Tripler; 07-17-2020 at 12:18 PM. |
07-17-2020 | #106 |
The fans turn on when u first start the car?
07-17-2020 | #107 |
No ,,, that's the garage AC running . Only thing I hear is the Vacuum pump and its very tight and only runs for a second or 2 . I found a huge leak underneath the plenum and had to mod the rubber connection with my previous plenum pull . .
07-17-2020 | #108 |
At the risk of sounding silly, and Im not trying to be condescending, but I didnt see anywhere in the thread where you had replaced or at least ohmed out your ignition wires or checked your coils.. unless I missed it... just a suggestion..
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
07-18-2020 | #109 | |
Ordered more gaskets for a plenum pull . Getting pretty efficient at plenum pulls at least . Looking into the emmisions first before another pull . What equipment do I need to purchase to make sure the coils are working correctly . Thanks for the input . Lost without the help of you guys on this forum and Mr Haibeck Sent from my SM-A205W using Tapatalk |
07-18-2020 | #110 |
Just a quick list of what I have upgraded or changed so far .
New fuel filter , twice . First was full of rust so thought a second switch out would help grab any more crap. Installed new serpentine belt Found and fixed large vacuum leak under plenum Installed a new IFPR Installed new Accel Injectors Installed new spark plugs Car only gets High Octane non Ethanol Shell 91 That's the list so far Sent from my SM-A205W using Tapatalk Last edited by Tripler; 07-18-2020 at 09:35 AM. |
