#91 |
![]() Join Date: Jan 2006
![]() ![]() ![]() *****TIP***** Do not adjust the coil height with the shock gear attached. It may twist the gear despite your best efforts not to. ALSO, MAKE SURE THE GEAR IS SEATED PROPERLY PRIOR TO PUTTING IT ALL BACK TOGETHER!!! Okay: what else? Ted |
#92 |
![]() Join Date: Jun 2004
Ted,
You have done a great job of illustrating and documenting the coil over installation kit of ours. I have some "new" pics of the upper brackets I'll post if someone can tell me how to or I can email them to someone to post. Thanks for all your hard work on this project. I will be mailing the first rear kit to -=Jeff=- this week. With all you have to do it is appreciated that you took the time to do this, thanks again! salute
#93 | |
![]() Join Date: Jul 2007
EDIT: also thanks for putting this together
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
#94 | |
![]() Join Date: May 2010
![]() Okay, here are -=JEFF=-'s pair!!! ![]() Here is a close up of the bracket and note how it is radiused. Carter is one heck of a Master Machinist!!!! ![]()
#95 |
SWEEET!!!!!!
Thanks Carter Thanks for posting pics Craig
#96 |
Jeff, you're welcome.
Carter, your machine work rocks big time. I'm brainstorming the next project for you..............
#97 |
#98 |
I could not prevent the upper portion from rotating. Also, you cannot verify the rears are not rotating. I twistedthe rears enough that I, luckily, popped the rear actuator off-- vice damaging it.
#99 | |
so to adjust ride height you need to unbolt the shock plate before turning the bottom adjuster? Thanks for all your help/work
#100 |
Yes. It is best. I used a strap wrench to try and hold it steady but the coil or shaft turned the top gear. I set the height I though I wanted then drove the car a few miles and let it settle.
Ted |
