Old 02-24-2009   #1
8upZR1
8upZR1's Avatar
Default Silver Box?
I have a stupid ? so please be nice.
What is the silver/metal box that sits on the trans tunnel underneath the radio? It has 2 sets of wires plugged into it. Thanks for any info.
Old 02-24-2009   #2
Default Re: Silver Box?
CCM Central Control Module.. it is the master module for the ECM and EBCM
the CCM holds the Odometer info.. as well as converts the info from sensor to display correctly on the LCD.
Old 02-24-2009   #3
What Jeff said
Old 02-26-2009   #4
8upZR1
8upZR1's Avatar
So what your saying is that its worthless and I should go ahead and toss it? Right?
Old 02-26-2009   #5
if you are going to toss it I will take it
if you are not using the OEM dash cluster anymore then you don't need it
