#21 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-22-2009 at 12:21 PM. |
#22 |
It was making the noise at that point I was hoping somebody wasnt trying to flag me down to tell me I was dragging my exhaust or something. It was good to see you Phil I was a little embrassed the girl was overdue a bath.
#23 | |
Not sure but a family photo when its all done is in order
#24 |
![]() Join Date: Aug 2006
#25 | |
Thanks for that Greg I was wondering if that was a heat or thermal barrier in a stainless lattice work that slipped over the piping?
#26 |
#27 |
And there we have it. Thanks Jeff hey did you get my PM on the bolts?
#28 |
#29 | |
![]() ![]() What you see in the pics I posted are:
http://vibrantperformance.com/catalog/index.php?cPath=1022_1035_1064_1113 (example) ![]() These flexes are gas-tight construction with inner and outer braided SS liners to help protect the SS bellows. I would have preferred to use even longer flex sections and added SS V-band clamps to ease of assembly but Corsa pipe on the driver's side did not allow for enough length between the cat outlet and the first bend to fit all of these components in and at the time I did not want to get into heavily modifying the Corsa piping. As it turned out the flex sections were all that was needed to help make assembly and removal of the exhaust system via the collector clamp joints a snap. I have about 750 miles on the sytem since installed and so far no problems to report except for an even a more accute case of perma grin. Last edited by Jagdpanzer; 02-22-2009 at 07:09 PM. |
#30 |
![]() Join Date: Dec 2004
Thank you Mr. Jag for that easy to follow explaination!
![]() I never thought about vibration isolation in our exhaust systems. Hummmm, I wonder if that contributes to the dreaded resonance issues??? Seriously, thank you for putting so much effort into the sharing your info! ![]()
