Old 2 Weeks Ago   #1
mikey435
Default Help with code 43 and 55
Good morning all took my 90 out last night car was running fine then service light came on and she wasn?t running right went home checked codes and found code 43 and 55. Any advice on where to start with these codes?
mikey435 is offline   Reply With Quote
Old 2 Weeks Ago   #2
Will69camaro
Will69camaro's Avatar
Default Re: Help with code 43 and 55
Had the same recently with mine with code 43 only. Did it by chance happen after driving and it being at operating temp a while and shutting off and restarting? Mine has done it a few times and it?s gone away. FSM points to it being a knock sensor. I just picked up a new one but have yet to install it.
If you don?t have a FSM I can snap a pic of the code 55 as well to help.
Will69camaro is offline   Reply With Quote
Old 2 Weeks Ago   #3
Karl
Karl's Avatar
The knock sensor is on the driver side and is mounted "dry" into the block so it can be removed and no coolant will come out.
I had a code 43 years ago and my knock sensor was not mounted tightly as it would spin without a socket. I would start there.
1985 L98 Blue On Blue *Sold*
Old 2 Weeks Ago   #4
Will69camaro
Old 2 Weeks Ago   #5
Karl
Karl's Avatar
Yep that's it.
Old 1 Week Ago   #6
Will69camaro
One thing I will say from quick search so verify it, is that code 55 is a O2 lean condition. I?d have some concern that if it?s running lean the knock sensor code may be related to it as well.
Old 1 Week Ago   #7
mikey435
I thought code 55 was a voltage code not a lean code
Old 1 Week Ago   #8
mikey435
I?ll check out that knock sensor when I get home thanks
Old 1 Week Ago   #9
Will69camaro
This is what I see in my 1992 FSM.
Old 1 Week Ago   #10
mikey435
Thank you I?ll check my fsm this weekend and let you guys know what I find
