Old 03-03-2020   #1
mcich7781
mcich7781's Avatar
Default C8R Corvette = DOHC V8
Just read an article from Hot Rod and viewed some pictures of the engine. Hot Rod insiders say it looks like this will be the power plant for the future Z06 or ZR1 models. The article mentions the C4 ZR-1. Link below.
https://www.hotrod.com/articles/excl...-iconic-sound/
Sent from my SM-G955U using ZR-1 Net Registry mobile app
mcich7781 is offline   Reply With Quote
Old 03-03-2020   #2
EvanZR1
EvanZR1's Avatar
Default Re: C8R Corvette = DOHC V8
While it's true that they have to run a production version of the race engine, I think they have some significant leeway in what's required. If I remember correctly, the head design has to be the same, but I don't think they are required to run the same displacement or crank design for production, and I'm not even sure if they have to run NA or if they could do forced induction on the production version of the engine.
I'm hoping they actually do an NA DOHC FPC with high rpm, but the C8 DCT is only rated to 7500rpm, so unless they already have a different transmission version ready, FPC may be a dream.
Evan
2023 70th C8 HTC, 94 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1
Old 03-03-2020   #3
If it's a FPC you want, let me know, I will be ordering another one for the LT5, during the next couple of weeks. It's no trouble to make more. Cost will be in the neighborhood of $6,500, balanced & nitrided.
Old 03-03-2020   #4
lfalzarano
I recall the Corvette C6R engines were built by Katech. It wasn’t a production engine, but most likely had a lot of GM parts.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 03-03-2020   #5
EvanZR1
EvanZR1's Avatar
Between you and Pete, you guys could get me into so much trouble...
Evan
Old 03-03-2020   #6
precast1
precast1's Avatar
Thanks Evan for the post.
precast1 is offline   Reply With Quote
