05-12-2018 | #11 |
Re: I-PASS mounting on the Z
I positioned it under and slightly in front of my Valentine 1 radar detector in the windshield cutout. With the V1 securely attached to the windshield with suction cups and the I-Pass underneath, I pushed the V1 tight against it. It held it there fine and always worked at the tolls. (FYI, my V1 was hardwired with the wire source at the fusebox on the passenger side of the dash [accessible when the passenger door is open]. The wire is then run up under the dash and out the grill in the dash center. Had to make a small notch in the edge of the grill. And full disclosure: Marc Haibeck did the actual work.)--Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 05-12-2018 at 10:44 AM. |
05-12-2018 | #12 |
Being registered in Florida my Z does not have front plate. License plate mount transponder fit nicely inside the front plate filler trim and works great.
05-12-2018 | #13 | |
Sent from my 2PS64 using Tapatalk |
05-12-2018 | #14 |
I had no idea you had ties to Florida Yun!!!
05-12-2018 | #15 | |
05-12-2018 | #16 |
05-12-2018 | #17 |
Cool! Thanks for sharing. I would have never guessed it. Sent from my iPhone using ZR-1 Net Registry
08-02-2019 | #18 |
I used 3M Velcro on a plate mount I-PASS. Used it 14 times over the past six months with no issues. Works great concealed.
Sent from my iPad using ZR-1 Net RegistryIMG_1078.jpgIMG_1079.jpg Last edited by Mr.Yuck; 08-02-2019 at 08:56 AM. |
08-03-2019 | #19 |
I have the OEM windshield and have tried several locations for the I-Pass here in Illinois. The only place it reads for me is the windshield cutout.
I love the idea of placing the transponder behind the front plate cover, that would solve a lot of issues.
91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
08-04-2019 | #20 |
I've had my NY EZ-Pass in the radar cut-out for quite a while. Works well there.
Front radar detector is mounted inside the front bumper near the front license plate. Front plate is where they target radar/laser.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
