03-12-2019 | #1 |
Vette-Lights
Just wanted to give a shout out to Cole at Vette-Lights.com
I've installed his headlights, fog lights, and many of the interior lights. He's been a great help and the lights have been great. I would certainly consider this a good source for us. |
03-14-2019 | #2 |
Re: Vette-Lights
Lucky you, Steve! It was trial and error for me. Now I have a drawer full of LEDs I can't use or refuse to use.
03-14-2019 | #3 | |
Re: Vette-Lights
That said, if you want to, I have a couple spare rectifiers lying around. And, if you want, I'll build a pair of "kits" to insert into that bulb's wiring to allow an LED replacement. I'll even include the LED bulb, if you want. This was the final design. And, the LED is quite a bit brighter than the stock bulb. Also, as an option, the gills can be festooned with LEDs to signal traffic along side of you as - wired into the stock turn signal.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 03-14-2019 at 09:10 AM. |
03-14-2019 | #4 | |
Re: Vette-Lights
Side marker you are talking about is small yellow piece? I gave up on it for now. If you could build me a kit for that light, I'll take it. Shoot me a message and let me know what I owe you. Now, I am jumping into 200 amp high efficiency billet alternator. Like anything else, not as simple as just bolting it in. Wire upgrade, to fuse or not to fuse, fuse vs. fused link wire, so on and on... Thanks. |
03-14-2019 | #5 | |
Re: Vette-Lights
As for your 200A alternator: It may not be as involved as you might think. For instance, an AWG 6 gauge wire between the ALT and the battery may suffice. And, unless you intend to add some high power accessories (e.g., an aftermarket stereo), you may need not do anything with the fusible links. C-Link
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 03-14-2019 at 07:52 PM. |
03-14-2019 | #6 | |
Re: Vette-Lights
03-15-2019 | #7 | |
Re: Vette-Lights
If all you're doing is upgrading the size of the alternator, except for maybe doubling up the wire between the alternator and the battery, you won't have to do anything with the existing fusible links. However, if you're adding something adding a substantial current load, then you may want to consider running a separate wire from whatever it is to the main buss (behind the battery) and install a fusible link to that wire.
03-15-2019 | #8 | |
Re: Vette-Lights
Thanks Paul! |
