04-20-2018 | #11 | |
Re: 2019 ZR1 @ Drag Strip WTH!!!
As stated YouTube "star" a lot of others have done it as well
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 04-20-2018 at 03:00 PM. |
04-20-2018 | #12 | |
From what I hear he makes 12,000 a month from you tube alone....I would guess that figure is a little high.Its probably close to ten grand a month .. He works for a small brokerage firm and I would guess his salary is maybe about 40-50 K from that..He also invests on his own.... He actually is well spoken and really has made a name for himself with his you tube videos.... |
04-20-2018 | #13 | |
cheers, G
'94 ZR1 LT5 - Dark Red Metallic '79 L82 4-speeds of fun '96 LT1 Borla, H-pipe, TB, CAI (Sold) "An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton |
04-21-2018 | #14 | |
peace Paul ZR-1 Net Registry Member #1494 |
04-21-2018 | #15 |
The 8 speed auto allows for drama free launches. 1.58 60ft, stock torque converter, and the stock (auto) 2.41 rear gear and it's 1st gear ratio of 4.56:1 ,
2nd 2.97 3rd 2.08 4th 1.69 5th 1.27 6th 1.00 7th 0.85 8th 0.65 As we saw, the auto equipped '19 ZR1 was decently into 5th gear as it trapped. The manual 7 (TR6070) speed gets the 3.42:1 rear gear and if the Z06 and ZR1 share the same TR-6070 trans ratios, it will have a 2.97:1 1st gear 2nd 1.61, 3rd 1.21 4th 1.00 5th 0.82 6th 0.68 7th 0.45
04-21-2018 | #16 |
You are correct, both Z’s use the same manual, but the ZR-1 has s torque reduction to protect the 1st 3 gears. The auto is likely faster.
04-21-2018 | #17 | |
04-21-2018 | #18 |
It is so you don’t have a drivetrain failure.
04-22-2018 | #19 |
There aren't many GM vehicles built since 1992-93 with the advent of the 4l60e transmission that don't have some sort or torque reduction or torque management. It was usually reserved for automatic transmission equipped vehicles. Many would drop engine timing advance during upshifts.
I wonder how the application of torque through a clutch as in the manual differs compared to the application of torque through a torque converter as in the auto trans vehicles? Are the manual cars more apt to have the front end swap positions with the rearend? Torque reductions is mentioned as part of the many nanny controls of the new Z. Active handling stability control with traction control
04-22-2018 | #20 |
There is a “ kind of predictive algorithm found in the dual clutch (automatics) to prepare for the next likely shift,” Alex MacDonald, Chevrolet’s Vehicle Performance ma manager.
