Old 04-18-2017   #11
epaul77055
epaul77055's Avatar
Default Re: 1990 radiator fans
One other thing I remember reading, when changing the part have the new one close by in case the Schrader valve leaks a little- (then you can quickly screw the new one on and minimize Freon loss) I didn't have that problem- still working properly to this day.
epaul77055 is offline   Reply With Quote
Old 04-19-2017   #12
Livin' in the 80's
Livin' in the 80's's Avatar
Originally Posted by epaul77055 View Post
yes there is a Schrader valve-very little Freon was lost when putting on the new part. A very short hiss when taking old part off.
My fans are on all of the time. I unplugged the connections and it still runs. does anyone have the fan wiring diagram? Both fans run with Marcs PROM in and all ac switches unpluged and the climate control off. Any input?
:Eagle:[URL=http://s653.photobucket.com/user/craigwhite84/media/Kelly%20Boat/IMG_0468a_zpso50qvl1y.jpg.html][IMG]http://i653.photobucket.com/albums/uu256/craigwhite84/Kelly%20Boat/IMG_0468a_zpso50qvl1y.jpg[/IMG][/URL]
1990 ZR1 Black/Black #2317
Livin' in the 80's is offline   Reply With Quote
Old 04-20-2017   #13
Livin' in the 80's
Update: Finally figured it was the A/C requesting the fans. Replaced the A/C Fan pressure switch(the one on the small line closest to the firewall--Took less than 5 minutes) Fans are working properly. Thanks for everybody's input.
How does that sensor work and how did you pin point the switch was bad? If I unplug all sensors, the fan still runs. I get full continuity at the two pins on the switch you are talking about. Is there a way to exactly see what temp the ECM is seeing from the coolant temp sensor?
Old 04-21-2017   #14
Livin' in the 80's
Sorted it out. The green connector on the ECM wasn't seated all the way in and I didn't have the PROM snapped in all of the way. All works now.
Lesson learned - pay attention to detail!!!
