08-20-2016 | #51 |
Re: Stuck!! No crank ! LF some input and help !
5AB,
I like the idea of a backup for the starting circuit. Having said that, I would have had the plenum off and the starter out w new contacts installed them button everything up by now. At the end of the day,'u should still do the "rebuild" on the starter anyway. My $.02.
08-21-2016 | #52 | |
It's 1130 now.. Heading home putting kids to bed. Getting a coffee and time to hit the garage.. Here's the plan based on dynomites write up .. Last edited by 5ABI VT; 07-06-2017 at 05:06 AM. |
08-21-2016 | #53 |
Maybe the final update ...
PROBLEM SOLVED !!!!!!!!! Ok so before I even began the relay mod.. Since yesterday I had been wondering how the purple wire end coming from the clutch switch would trigger the relay to put power through from battery to solenoid. Why? Because I was testing it with the volt meter and when key forward I was getting nothing from the starter relay at the kick panel. I was confused by this and forgive me for asking so many questions.. Long story short I pulled the manuals out from the boxes in the shed and found the diagram. I had a connector that didn't have the same color wires as the diagram and I was really confused. I looked again underneath and was convinced at what I thought was the clutch switch. After googling the switch I found an eBay listing where it mentioned it was for all years of the c4. It was nothing like what I thought was the clutch switch :/ So in a beautifully edited photo by me .... and yes I believe most of you are aware what the clutch switch is ! I tested the switch plug with my multimeter and no change with the clutch depressed. I cut the wires, tied them together .. Turned the key and she cranks. Thanks to everyone for chiming in and hopefully this may help at least one person in the future. I figured since it was a button that was depressed by the clutch pedal that it was the switch. Clearly I was wrong. The actual clutch switch is higher up and the wires are sheathed in black so the colors were also not visible to me. On the bright side I feel much better, I bypassed the key resistor and the clutch switch and have an emergency wire still above the battery tucked away and I have some more experience with a multimeter to boot ! Last edited by 5ABI VT; 07-06-2017 at 05:06 AM. |
08-21-2016 | #54 |
That IS a beautifully edited photo And.......this is a 94' ? Prolly note that this is a 94' in above post
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-21-2016 at 06:24 PM. |
08-21-2016 | #55 |
I did make my friend stick his head under there and take a look.. He saw the white switch.. Whatever it is and thought it was it too lol. Anyone know what that other switch is for ? I have a relay all soldered and ready to add if need be. Now to pull the plenum to do the wires and coils and I'll clean up the starter too while in there. Before I ask I will search on possible parts to rebuild it or get it as new as possible when I do take it apart.
08-22-2016 | #56 | |
See Starting Issues by Marc Haibeck But you are saying that on your 94' the Clutch Switch does not close so GM must have put in a smaller capacity clutch switch given there is only .2 amp on that circuit or Could it be a mechanical issue with the Clutch movement not closing the Clutch Switch??. I did not install the Relay in my 95' since it appeared GM solved the Clutch Switch issue??? Convince your friend to remove the Clutch Switch so you can check it out since you no longer need it
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-22-2016 at 01:43 AM. |
