Old 02-03-2016   #21
C4Ray
Default Re: What are the widest tires street legal that can fit a ZR-1 (with aftermarket whee
Originally Posted by WARP TEN View Post
I put the Michelins on the stock 17" rims and they are great tires, albeit not inexpensive.
Bob - Would you mind posting a pic from the rear, of your tires? A complete rear shot .... if possible ?
C4Ray is offline   Reply With Quote
Old 02-03-2016   #22
OK Ray-- Here are a couple I just took and one at Beech Bend (thanks Gunny). Best I can do. Bob
Old 02-03-2016   #23
rebelz
rebelz's Avatar
Originally Posted by geezer View Post
Would like to replace my Michelins on my stock '90. Fronts are available from Michelin ( 275/40/17) but rear ( 315/35/17) are not . Michelin can supply rear 335/35/17.
Anyone had experience going from 315 to 335 ??
I am running with that exact configuration, Pilot Sport PS2's. I checked with Michelin tech and they said that they would be fine on my stock '93 wheels. The fit well, no sidewall bulge, they perform perfectly. I used to use Goodyear GS-D3's but they were unavailable at the time. Comparing the two, I'll stick with these. I must admit that the Goodyear's are better in wet conditions, but the rubber got hard pretty quickly. There is a two mile an hour difference in speedometer reading.
REBelZ
'92 ZR-1 Yellow/Black #031
rebelz is offline   Reply With Quote
Old 02-04-2016   #24
cvette98pacecar
Robert,
The fronts on the Callaway are what? 275 or 285?
Dom, They were 285 F1. I now have 275 PS2.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
[COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member
NCM Lifetime Member #2655
Pacecar Registry Member
[COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR]
[COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR]
[COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR]
1991 Callaway Aerobody ZR-1, DRM 500
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 02-04-2016   #25
Curious about any issues w ABS. I went from 275s up front to 285s due to the
bump 325s to 345s.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-05-2016   #26
C4Ray
Great pics Bob.
Old 02-10-2016   #27
batchman
bump 325s to 345s.
I've run a variety of sizes and degrees of stagger on 2 different C4s and have found the ABS to be very accommodating.
Actually, I thought I was just never triggering it.
Then one day I had a bad hub the day before an event. Only 1 good spare and it was from the other car, bolts up fine but no ABS. I figured that'd be OK since I "never" feel the ABS kick in.
Sure enough I had lockup at every hard brake & turn. Seems I use the hell out of the ABS but never knew it.
PS I've been running 315/335 17's for a long time, and pretty much cantilevered at that - just lacking tread . Just a couple small rubs - nothing damaging.
HTH,
- Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's
DRM chip/Watson/Borla/lid/LW batt&headlights,
springs, shocks, pads & lines, quick rack & Turn One,
camber brace, 32/22mm sways, A/C halfway deleted
17x11 & 12 CCW's, 315 & 335 Hoosier A6s
[/I]
Old 02-11-2016   #28
WydGlydJim
WydGlydJim's Avatar
335/30/ZR18 Toyo R888 Proxes just barely fit between the lift plates.
If I have it centered perfectly, the tires fit exactly at the same width as my lift plates.
I like em.
2009 LS9
1990 LT-5/sold/Bought my Baby back
1994 Lingenfelter LT-5/sold
1973 LS4/sold
WydGlydJim is offline   Reply With Quote
Old 02-11-2016   #29
Wow, those are wider then my ex gf's rump
Old 02-11-2016   #30
Jagdpanzer
Jagdpanzer's Avatar
bump 325s to 345s.
Dom,
If you need them I can turn you out a set of custom count reluctor wheels. Needed them for mine when I went staggered 285/35R18s and 345/30R19s so the ABS and ASR sytem alarm light would stop freaking out after a few miles. I know a few guys who have gone with this tire size combo and did'nt have an issue but I wasn't so lucky. At least I know my ABS and ASR systems are fully functional.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
