03-11-2015 | #1 |
Ported Intake
Early style (90-92) ported plenum and injector housings for sale. Plenum ports are 36mm at gasket surface and grow larger upstream, inside of plenum has been extensively worked, corner bolt holes have been sleeved for alignment, throttle bores have been enlarged to accept 63mm throttle body. Injector housings are 36mm through secondary ports, secondary bosses reduced and contoured, primary ports are 36mm halfway down the ports and reduce to 34.5mm at head gasket surface for optimal transition to stock 32mm primary head ports, primary injector bosses have been eliminated.
Easy 25hp bolt on for stock LT-5. Exterior refinishing is recommended, can arrange top end powder coating for extra. $1500 outright.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 Last edited by Locobob; 03-11-2015 at 09:28 PM. |
03-11-2015 | #2 |
Re: Ported Intake
03-12-2015 | #3 |
Re: Ported Intake
I bought a set of these from Locobob. No issues, and nice bolt on power. Thanks Bob. -Steve
03-12-2015 | #4 |
Re: Ported Intake
Excellent work Bob!
03-12-2015 | #5 |
Re: Ported Intake
Any trades for a stock plenum and housing? I'd be interested in the offset cost . Robert
03-13-2015 | #6 | |
Re: Ported Intake
Yes - forgot to post - $900 + shipping with core return..... Just in Case Robert is off for the weekend
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-13-2015 at 12:44 AM. |
03-13-2015 | #7 |
Re: Ported Intake
Gee, that might even be the core I sent him.
03-13-2015 | #8 |
Re: Ported Intake
You would be correct Steve... not turning these out as fast as I used to.
Daryl - yeah I'll do $900 with exchange, do you have another Z or something? thought yours was already all done up?
03-13-2015 | #9 |
Re: Ported Intake
If it matters, these came off my 90 with 61K on them. My new ones look most beautiful all powder coated and going down the road much faster.
03-13-2015 | #10 |
Re: Ported Intake
Ok so if you send your stock plenum the cost is 900 plus the shipping?
Just curious.... |
