10-08-2014 | #51 | |
Re: Pulling the Plenum for the first time...
10-09-2014 | #52 |
If I did have a vacuum leak, wouldn't the idle be fluctuate all the time? I just don't see who it could be leaking. I have used a vacuum pump to check all the connections and nothing seems to be leaking.
Looking for a ZR-1 1985 Yamaha RZ350-NOT STOCK 1971 Yamaha AT1-Middle of a restoration |
10-15-2014 | #53 |
Here is a little video of what I am dealing with when the car is fully warmed up.
http://youtu.be/TjD4C59Q9gA
10-16-2014 | #54 |
I had a suggestion from Marc Haibeck that it could be the PCV grommet for the valves. I checked that today and it was ziptied to the tops of the PCV valves. Is there anyway to pressure test that system?
Another thing I noticed today. If the AC is on the idle is pretty much perfect. It doesn't fluctuate at all. Is that normal? Could this all be IAC related?
10-16-2014 | #55 |
That's because the AC put a load on the motor and moved the idle to a different/richer part of the VE table. Suggests to me that your oscillating idle is due to a lean surge. The VE table at idle needs to be flattened out, probably along w the SA table altho I would look at Closed Throttle Idle SA setting.
10-17-2014 | #56 | |
10-20-2014 | #57 |
Any idea on what to look at?
