Old 10-15-2013   #11
bamawrx
Default Re: question
Which would be passenger side rear of engine.
bamawrx is offline   Reply With Quote
Old 10-15-2013   #12
bamawrx
Wouldn't #2 and #6 fire at same time?
Old 10-15-2013   #13
Originally Posted by bamawrx View Post
From your photo my car has #6 cylinder wire attached to your #2 label.
Where is the #2 (front first cylinder on passenger side) wire attached?
Firing order is 1-8-4-3-6-5-7-2
Old 10-15-2013   #14
bamawrx
Disappears deep under plenum. My best guess....the #6 spot.
Old 10-15-2013   #15
bamawrx
I have no spark on six. Plug is carboned up. Marc suggested to use volt meter to check continuity between wire pairs to rule out bad wire verses pack. I hope its bad wire because I can change it without plenum removal.
Old 10-15-2013   #16
Default Waste Spark Ignition
Change plugs on number 6 plug wire....using good plug. You can change a plug wire without removing plenum??
1 and 6 fire with 1 TDC compression and 6 TDC exhaust.
8 and 5 fire with 8 TDC compression and 5 TDC exhaust.
4 and 7 fire with 4 TDC compression and 7 TDC exhaust.
3 and 2 fire with 3 TDC compression and 2 TDC exhaust.
Then we get to 1 and 6 again but this time 6 is TDC compression.
Drivers side bank from front to rear:
1 3 5 7
Passenger side bank from front to rear:
2 4 6 8
Old 10-15-2013   #17
bamawrx
Ok I was right about cylinder numbers. Definitely #6 wire in #2 spot. Any harm in leaving it there?
Old 10-15-2013   #18
I guess not since it is a waste spark ignition.......
Old 10-15-2013   #19
Franke
I think the story goes that the cylinder under compression would fire and the other one would be wasted spark. Yes - No?
Old 10-15-2013   #20
Paul wrote a good description...of waste spark.
It's called a "waste spark" system. Cylinders are twinned, but only one at a time is in compression cycle when the spark arrives.
Just a point of interest: Because current flows in a loop through the block, coil and plug wires/plugs, the current is the same through both spark gaps. However, due to the much higher compression air pressure in the cylinder about to fire, the gap resistance to flow is much higher, resulting in the heat generated in the spark to be proportionately higher than that in the waste spark cylinder. In other words, the majority of the energy expended in the circuit is concentrated in the compression cylinder, resulting in very little actual "waste", really.
FWIW,
P.
