Old 08-25-2012   #1
chriskinzel
chriskinzel's Avatar
Default No Start
I just replaced the 2 prong coolant sensor and now it won't start. When ii took the sensor out I lost some coolant (about 1/2 gallon) down the valley. The car turns over but will not fire. Did I get something wet that ii shouldn't have? Does it just need to dry?
Thanks in advance
Chris
91 ZR-1 Red on Red #922
chriskinzel is offline   Reply With Quote
Old 08-25-2012   #2
scottfab
scottfab's Avatar
Default Re: No Start
Thanks in advance
Chris
Possibly got coolant on the coils but I would start at ground zero.
Assume nothing.
Check spark (pull one plug and listen for spark)
Check fuel pressure.
Since it is cranking you can rule out the common "no start" culprits.
Scott
Old 08-25-2012   #3
chriskinzel
I assume you removed the Plenum?
I assume you unplugged and plugged the electrical connections to the DIS?
What is the DIS?
Old 08-25-2012   #4
scottfab
scottfab's Avatar
I wouldn't be pulling the plenum or replacing the engine just yet.
Run some simple check first.
Do you have a good spark a the plug end?
Do you have fuel pressure?
Scott
Old 08-25-2012   #5
chriskinzel
45 PSI fuel Preasure, but no spark. Will it dry out?
Old 08-25-2012   #6
chriskinzel
Distributorless Ignition System......black box bolted up under rear of Plenum with dialectric greese between black box and Plenum.
Several electric plugs are mated to DIS from underneath and from the rear of the Plenum area.
I didn't totally pull the plenum, just lifted the front. I didn't unplug the DIS.
Old 08-25-2012   #7
chriskinzel
Thanks for the reassurance. I have a box fan blowing down on the plenum now. I will wait until tomorrow and try it again. I just get scared when things don't work as planned. Thanks again!!
Old 08-26-2012   #8
scottfab
scottfab's Avatar
this should work. You might inspect each connection at the coils and as was mentioned. Check the drainage in there. Should be no standing water.
Scott
Old 08-26-2012   #9
chriskinzel
Cool Re: No Start
OK got up this morning and tried to start the beast on the way to work. Still no start. I am at work for the next 48 hours, so when i get home on Tuesday I guess I will repull the plenum and see if there is any conections that I missed. The drain works good, and I did flush with water. It seems like this car is either go fast, or no go at all.
Old 08-26-2012   #10
rhipsher
rhipsher's Avatar
Im with Dynomite on this. DIS modual may not be unplugged at the modual but might have come unplugged at the other end at the coil. It will crank all day long but wont start. Its a tight spot to get your arm down in to. But I'll bet thats it. It happens to me 50% of the time when I have to lift the plenum.
