03-15-2012 | #11 | |
Re: Summary of Bolt Torque, Sealants, Loctites and Header Bolt Kits
P.
03-15-2012 | #12 | |
Re: Drain plug torque
I used the blue LT - on the header bolts that I got from ACE H/W. I used them inconjunction with a new gasket from Jerry. For insurance, I smeared a film of red high-temp RTV on both sides of the gasket - overkill on a new one, perhaps? AnywayZ, no leaky after a couple years and counting. P.
03-15-2012 | #13 |
Loctite 242, 243 & 262 is only rated to 300F. Heat is used as an aid to dissassembly. Vibration is the cause of fastener loosening and only occurs under running conditions. I haven't checked the actual, operating temperature of the cyl head at the exhaust port, but I would expect temperatures in excess of 300F.
Considering the difficulty of accessing header bolts and the small tools used, I would not recommend the use of Loctite on header/manifold bolts. It could make disassembly problematic.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 03-15-2012 at 10:40 AM. |
03-15-2012 | #14 |
Thank you Gentlemen, Cliff, Paul and Jerry.
Paul, I use some form of permatex on all my gaskets via buttering so I'm hearing Ya with that one! Cliff, what can I say? You are complete right down to the crossed "T-ees" and "dotted I's"! I'll go run down the links and do some reading. Thanks amigo. Jerry, I never considered the temp limits of any of the loc-tite products. My bad. You're obviously right about the temps at the exhaust ports I would dare say. Sooo, I guess I'll be looking into thwarting the mechanical vibration that will loosen the header bolts with a mechanical solution. Thanks for the facts on that stuff! Thank You Jerry. Tom
07-22-2012 | #15 |
Two questions. First, following up a separate discussion with Jerry, have any of you seen an aluminum oil drain plug (Jerry says he has not) and second, what size is the oil drain plug?
Thanks! John
[SIZE=1] AustinJohn in Austin, Texas '90 Black/Gray ZR-1 #1723[/SIZE] [SIZE=1] Ported intake, Haibeck Chip, CORSA exhaust, 4.10 rear end, Hurst shifter, drilled/slotted rotors, stainless brake lines, 32mm sway bar, 170º thermostat '94 Red/Gray Coupe[/SIZE] [SIZE=1] Stock '85 Black/Black Coupe[/SIZE] [SIZE=1] Anything but stock (Lingenfelter 383 and every Lingenfelter mod available in '88 including 3:54 rear end, big brakes, Centerforce clutch, MSD electronics and Borla exhaust.) True "barn find" restored/upgraded by me beginning in 2010.[/SIZE] |
07-22-2012 | #16 | |
Andrew
2004 Z06/Z16 LeMans Commemorative Edition 1991 ZR-1 #302 White/Gray (sold) 1991 ZR-1 #1147 Red/Saddle (sold) |
07-22-2012 | #17 | |
07-22-2012 | #18 | |
I think the stock plug uses a 13 or 14mm socket. Nothing exotic.
07-22-2012 | #19 |
the 5/8-18 is correct for the thread & pitch, 9/16 for the box-wrench and I don't believe a ZF fill or drain plug is aluminum. Mine are "magnetic"! Those are in an NOS "Blue tag" but I believe I've checked those in the car also!
07-22-2012 | #20 |
You're right. The trans case is aluminum, the plugs are steel. Thanks for the correction.
