Old 04-27-2011   #1
sjs
Exclamation Knowledgeable Tech -Starting/Performance problem needing assistance
Hello everyone, I am new so please bear with me. I am new to the forum and this is the first zr-1 I have owned (90 model w/100k). Bought it last year, runs pretty good but secondary actuator does leak. I am an engineer but hate to admit I haven't bought a service manual yet (toys never break do they? LOL) Anyway, drove it for about 3k miles last year, wife drove it the first day of spring and as she turned in the drive it ran rough and died. Would start and run, but sounded and smelled flooded - would start after it dried out ... but would die. Put it in clear flood mode and will start but runs tough for a few seconds and dies. It used to start wonderful and run hard .. now it is becoming an annoyance and a reluctant wife is starting to loose faith and trust in her first vette. So if anyone has any ideas I would love to hear from the people who know the most about them. When it does run it pulls 11in of very steady vacuum at a low/rough idle , I thought it sounded throaty but funny (faint popping through the intake (had filter out), and tested fuel pressure at 39 psi (it does hold pressure too). So I am at a loss for what its malfunction is as I am NOT heavily familiar with this engine - not near as well as an l98 i used to have in a trans am. Could this exotic 4 cam engine have a jumped cam as they are known to have tensioner problems? But why does it have steady and almost good idle vacuum? Bad injectors ? But why will it run good for a few seconds before going down and why do the hold pressure (ie not leak), Scanner showed only lean code and secondary actuator code (i assume from its slow secondary vacuum leak) ... So I assume spark and ecm are okay since it kinda runs ....
Anyway, LT5 experts ..... please help and thanks in advance.
sjs
sjs is offline   Reply With Quote
Old 04-27-2011   #2
Default Re: Knowledgeable Tech -Starting/Performance problem needing assistance
Since the injectors are the first thing to fail I would look at those first.No trouble codes,check engine light?Regardless the problem is not a major one,these motors are not known for breaking.
Old 04-27-2011   #3
While I do agree completely with Z51Jeff, regarding the need to ultimately replace original injectors, especially for 90~92 models, I would also suggest the following posibility that can be easily checked & remedied if necessary.
One of the more common ocurrences is a MAP sensor hose that has come loose. The LT5 with its waste spark system, requires that during starting, the key is held in the start position momentarily after the engine starts. Otherwise, on ocassion, the engine will backfire and the suden manifold pressure will blow the connector hose (plenum to MAP sensor) off.
Here is a photo showing the placement of the MAP Sensor hose.
Old 04-28-2011   #4
gbrtng
gbrtng's Avatar
When my 91 sneezes and blows off the MAP hose it sets an SES code and light.
sjs: does it set any SES codes?
Old 04-28-2011   #5
tccrab
tccrab's Avatar
At 100k miles I'm willing to be that it's already had the injectors replaced.
That being said, it could still be bad injectors, especially if the previous owner had them replaced with more of the Multecs.
Check the MAP hose first as Jerry said above.
Maybe one of the Brotherhood local to you wouldn't mind meeting with you for a semi-educated diagnosis.
TomC
'Crabs
Old 04-28-2011   #6
Jagdpanzer
Jagdpanzer's Avatar
Where abouts in Kansas are you located?
I grew up in Garden City, KS and now live in Northern Virginia.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Jagdpanzer is online now   Reply With Quote
Old 04-28-2011   #7
Kb7tif
sjs
You have come to correct place.
Old 04-28-2011   #8
sjs
We are up in the northeast corner by Manhattan KS, GO KSU!
Old 04-28-2011   #9
sjs
THANKS TO EVERYONE FOR THE ADVICE .... !!!!
Just an update and to answer some questions, I did check the MAP sensor and hose, but thanks everyone who mentioned it as it is very important. Unfortunately it reads okay and correctly on the scan tool (MAP and BARO) ... I even tried to fake the motor our with a hand vacuum pump on the sensor, car still starts and runs the same, runs for a few seconds then loads up and dies. Also like I said earlier then only 2 codes are lean and secondary operation, other than that it is clean. Plan to work on the secondary actuators, but have to know what is wrong with the rest of the motor before pulling the plenum off. Does anyone know what pulse with should be on a 70deg day? Mine runs about 7.5 ms .... wondering if that is normal >>?????? If it is may just be junk injectors .... just thought it strange that they are bad but don't leak down at all ??@#$@???? I would think the spray would have to be just awful to make it run this bad. You can squirt raw gas in the intake manifold and make it run better than it is right now! Low crank and idle vacuum still concern me a little ... does anyone know what a ZR-1 should have for crank vacuum and idle vacuum ??? ARE THEY SPECIAL or the same as a L98 or LB9? Again thanks all for the expert help
Old 04-29-2011   #10
zr1don
Idle vacume should be 18 - 20 in, inj pw at idle should be around 4 ms, idle fp should be around 46, 39 is definitely low.
Tags
no start, performance problem, runs rough
