Old 10-12-2009   #1
xxxscimitarxxx
Default do these brake calipers and rotors fit our cars
as the heading says......
these are from a C6 l think.....Brembos?.....about a year old.....front and rear but this is the only pic l have so far
got a buy pending for $800
are these a direct replacement or is there any thing else l would need to fit to a 90/92 Z
top and bottom joints etc??
xxxscimitarxxx is offline   Reply With Quote
Old 10-12-2009   #2
Jeffvette
Default Re: do these brake calipers and rotors fit our cars
Those are the 993 Porsche Calipers. Commonly referred to as "Big Reds"
They will fit, but when you look at the hat, they are much thicker and will push the wheel out further.
Old 10-12-2009   #3
xxxscimitarxxx
for the fronts I think lm getting the whole joint in the deal as you see it....then hopefully just fit in between my A arms (thats the hope anyway)
Q....is there an issue with pushing the wheel out on that hub or should l just strip of the rotors and calipers and fit to my Z stock assembly (if they do that is)
and is there any major braking improvement to be expected or am l just wasting time and money with this
Old 10-12-2009   #4
How different are the 933 "type" Porsche Calipers for C6 (that has Corvette on them) from the 933 Porsche Calipers for a 933 Porsche?
Will the 933 "type" Porsche Calipers from a C6 as per picture above fit a 1991 ZR1 if you change rotors?
I assume the red brake calipers from a C5 stamped "Corvette" will fit a 1991 ZR1 without changing rotors or other hardware including brake lines?
Old 10-12-2009   #5
xxxscimitarxxx
errrrrrrrr
so what do l have here in the pic?
C6 (porsche 933 type) calipers
and rotors from what
will any of this fit my Z ??
Old 10-12-2009   #6
gbrtng
gbrtng's Avatar
Yes, the issue is that the roll center of the front suspension is disturbed and the loadings on the wheel bearings are changed causing them to wear faster, and handling at the adhesion limit is different.
When you buy the system from Guido or his suppliers for the C4, they provide rotor hats that are thick enough for the caliper to clear your specific wheels. The outward spacing for the 91 wheels is about 7/8", and for the 94 wheels about 3/8". I don't know about the 90 wheels.
The braking is impressive and in the many years I used this system on the track, I never faded the brakes. Replacement rotors and pads are for a twin turbo 993 Porsche and pretty pricey. Pay your money and take your choice.
For street use and bragging rights, save your money - use the stock C5 calipers and rotors (or just keep it stock).
Old 10-12-2009   #7
xxxscimitarxxx
lm sorry.....lm lost
rotors in the pic are 933 porsche
calipers are C6 ?
cant (or shouldnt) use the rotors
if l (can) use the calipers l need different rotors ?
Old 10-12-2009   #8
gbrtng
gbrtng's Avatar
You first need to find our exactly what you are trying to buy. I and Jeff think those are Porsche 993 calipers but I don't know what they are being used on now. They probably came from this source:
http://www.movit.de/rahmen/corvette.htm
Old 10-12-2009   #9
calipers are C6 ?
xxxscimitarxxx .....I am confused also Those calipers in your picture do not look like either C6 or C5 calipers.
I was under impression that C6 calipers (They look like Brembo) would not fit a 1991 ZR1 and that C5 calipers WOULD fit a 1991 ZR1 without changing the rotor
I am not sure if the brake bads are larger on the C5 calipers or if C5 calipers give you more braking than standard ZR1 calipers. The C5 calipers I have seen on ZR1s definitely look nicer being red and having Corvette stamped on them in white letters.
I painted my ZR1 calipers red
Old 10-12-2009   #10
xxxscimitarxxx
Ok guys....thanks
I think l will pass on the deal.....lm sure l can pick up C5 calipers for what lm paying on this uncertain package
thanks for all help
what would a guy do owning a Z without all you other guys helping out
viva la register
Dave
