10-07-2009 | #1 |
o2 sensor code 45
I have a 90 ZR1 with a slight misfire,and an OBD code 45 {left oxygen sensor}.Can it be just a bad o2 sensor or is there something else giving me the code? Any suggestions?
10-07-2009 | #2 |
Re: o2 sensor code 45
Possible leaking injector.
10-07-2009 | #3 |
Thanks,I'll check it out. Is that possible with only 4000 original miles on the car?
10-07-2009 | #4 |
10-07-2009 | #5 |
Yes,they are original. So is everything else on the car ,including the tires!
10-07-2009 | #6 |
The original Multec fuel injectors are sensitive to the ethanol in today's gasoline.
There has been a near 100% failure rate on these. Your choices are: $$$$ RC Injectors $$ Accell $ FIC's rebuilt MSDs TomC "Crabs"
10-07-2009 | #7 |
Thanks guys,Ill look into new fuel injectors.
10-08-2009 | #8 |
FWIW, my FICs appear to be brand-new Bosch injectors.
10-08-2009 | #9 |
I got a set from Jon last December and installed them in April. I was under the impression, at least the set I bought, to be reconditioned (as opposed to rebuilt) Bosch units.
Nonetheless, for $365 for all 16 was affordable and my 94 has never run this good! |
