Old 10-06-2009   #1
ckulchar
ckulchar's Avatar
Default clutch slave master or slave cylinder?
How can I determine if my clutch master or slave cylinder is bad? Only drove the car twice last year and twice this. The pedal has been soft for awhile now. The clutch master resevior is empty. Thanks in advance.
ckulchar is offline   Reply With Quote
Old 10-06-2009   #2
ckulchar
ckulchar's Avatar
Default Re: clutch slave master or slave cylinder?
Just noticed on the Advanced Auto Parts website. They list the clutch master and clutch slave both by Perfection. The mounting plates appear to be thin and bleeder on the bottom according to the photos. FWIW
Old 10-06-2009   #3
Jeffvette
For the slave, reach up under the dash along the firewall, if the foam backing is wet it's the master. If it's dry, it's the slave.
Old 10-06-2009   #4
ckulchar
ckulchar's Avatar
How do you "remove the sound insulator panel from under dash"? Is that the plastic piece that covers the top half of the clutch pedal?
Thanks
Old 10-06-2009   #5
Jeffvette
You don't even have to remove the panel. Just reach up behind the pedal area and the carpet is cut. Just peel it back a smidge.
Old 10-06-2009   #6
Kb7tif
Is there any under car leaking? Fill the reservoir.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 10-06-2009   #7
bdw18_123
Jeffvette's continually changing eye-candy avatar makes it hard to focus on the thread!
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 10-07-2009   #8
tf95ZR1
tf95ZR1's Avatar
As long as you are going through all the effort,
why not replace both? And wouldn't you be
pissed off (can I say that here?) if you had to
take it down again in the near future to replace
the old part? Unless one is new, my recommendation
is to replace both the master and slave.
Old 10-07-2009   #9
zfdoc says that if you do have an issue with the clutch hydraulics, the best solution is to always replace the master and the slave.
http://zfdoc.com/
check it out.
