Old 10-05-2009   #1
RedRiderZR1
RedRiderZR1's Avatar
Default 335x30x18 tires
Will these tires fit the rear of a 90 w/o tubing? I have some tires I would like to put on there with the ronal wheels. Probably would need a spacer for the wheels, but curious if they would fit.
Thanks.
1990 Bright Red ZR1 #41
ZR-1 Net Registry Founding Member #415
RedRiderZR1 is offline   Reply With Quote
Old 10-05-2009   #2
Default Re: 335x30x18 tires
depending on the offset of the wheels and if the car is lowered might cause them to rub..
I am looking for that size tire and I am curious which brand you are planning on using.
I need those as well as a 275/35 or 285/35 18" front tire. but having a tough time finding matching fronts and rears
-=Jeff=- is online now   Reply With Quote
Old 10-05-2009   #3
I spoke with massimo(Max76) the other day and he just bought a set of the Vredestein Setantas' that look pretty nice. Pricing looked competitive with the Sumos.
Old 10-05-2009   #4
no 335/30R18
Old 10-05-2009   #5
RedRiderZR1
I have the BF Goodrich G force KDWs. 275x35x18 front and the 335x30x18 rear. Offsets of the rims is the only question. I think the fronts will fit, the rear possibly with a spacer. That's why I was wondering if 335s would fit the rear without sticking out or rubbing on the inside.
Old 10-06-2009   #6
batchman
My race rubber is 335x30x17, no issues. Car is lowered "some".
FWIW I'm running them on A-molds with a spacer.
Cheers,
- Jeff
[/I]
