Old 10-03-2009   #1
rhipsher
rhipsher's Avatar
Default Donor for throttle body.
After drilling and tapping out to 8-32 threads I needed 4 8-32 socket head screws. I found an unusual donor for them.
This guitar has seen many gigs but is retired and has become and organ donor for my throttle body. 8-32 screws galore.
Now just grind them flush and wallah! Now when I hit the gas I might hear some guitar solos under the hood.
Old 10-04-2009   #2
Default Re: Donor for throttle body.
Where did your dag go?
A26B is online now   Reply With Quote
Old 10-04-2009   #3
rhipsher
rhipsher's Avatar
I don't know what dag means. You'll have to enlighten me. I'm not up to speed on all of these abbreviated words.
Old 10-04-2009   #4
tf95ZR1
tf95ZR1's Avatar
DAG is the goop applied on the shafts to seal them against the throttle body.
Old 10-04-2009   #5
It's also in the throttle body bore(s) to seal the butterflies when closed so the IAC valve can do it's job. It looks like gunk and sometimes gets cleaned out inadvertently. Result is no seal and high idle.
Old 10-04-2009   #6
rhipsher
rhipsher's Avatar
Ok. Then my next question is where do I get the stuff. If I can get it locally I would prefer that. There wasn't much of anything in the throttle body when I took it apart. It was pretty clean and idled at 850rpm's.
Old 10-04-2009   #7
tccrab
tccrab's Avatar
Info on DAG from Marc Haibec's website:
Dag is a general purpose material that is graphite based and is applied like paint. It's used in various industrial applications that need properties like a thick material buildup, low friction and high temperature range. DAG is a trademark of the Verick, Acheson Colloids company.
TomC
Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-04-2009   #8
rhipsher
rhipsher's Avatar
Ok. So is it used on all throttle plates. And is it available at any automotive store.
Old 10-04-2009   #9
bdw18_123
I need that DAG stuff too. I've search for it or similar equivalents but can find nothing. There has got to be some similar type of sticky, goopy stuff that you can buy that will do the same thing.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
