Old 08-26-2009   #1
ittlfly
Default Tech 1A
Hey guys...I wanted to pick up a Tech 1A off that auction site some time. However, they are usually advertised with a lot of accessories. My questions is: what exact cartridges are REQUIRED to make it work on my 94? Never owning one makes it very confusing.
Thanks
1994 ZR-1 # 0102...SOLD
ittlfly is offline   Reply With Quote
Old 08-26-2009   #2
Default Re: Tech 1A
Thanks
As many as you get. Most modules have the year model covered on the top side of the cartridge. At a minimum you need the following for your year
The ABS system
The ECM system
The Body System/ Chasis
EEPROM
These are going off memory but there are a lot of cables and adaptors you will need at well
Old 08-26-2009   #3
John Boothby
John Boothby's Avatar
Default Re: Tech 1A
The cartridges are identified like this: "GM 81-92 ECM CARTRIDGE"; "GM 88-92 BODY SYSTEMS CARTRIDGE", etc. You should get cartridges that cover your car. You should also get a manual for each cartridge. My car is a 1990 so the above cartridges cover mine. You also need a vehicle adaptor that fits your ALDL. Mine is a 12 pin. The Tech 1A should come with a power cord that plugs into the cig lighter, and a 14 pin cord. It also may come with a self test adaptor and/or auxillary instrumentation cables such as a "Multimeter test lead".
I still need a "GM88-92 BRAKE" cartridge pn: TK03030B if anyone happens to have one.
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
John Boothby is offline   Reply With Quote
Old 08-26-2009   #4
ittlfly
Default Re: Tech 1A
Thanks much for the information. I'd sure like to pick up one of these things as it would make following the flow charts in the FSM a lot easier.
Old 08-26-2009   #5
phrogs
phrogs's Avatar
Default Re: Tech 1A
I just picked up a tech 1 off a guy on craigslist and it came with a ton of cartriges, only One I have used yet is the mass storage one.
Thing showed me when I turn off my # 6 injector the motor runs the same when I turn off the others the motor starts to bog down so I have a dead cylinder at the moment! this thing confirmend what I had already though was my problem cylinder but its sweet!
JOHNNY P
Currently own
Old 08-27-2009   #6
ittlfly
Default Re: Tech 1A
Yep...that's exactly why I wnat one.....besides, Crabbs needs diagnostic the help.
Old 08-27-2009   #7
Default Re: Tech 1A
Johnny is there a procedure to delete the old data on the mass storage cartridges? I have a lot of those little buggers.
Old 08-28-2009   #8
DaveK
Default Re: Tech 1A
Does the tech 1A do anything that my AutoXray 6000 won't?
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 08-28-2009   #9
Default Re: Tech 1A
Yes If you want to know PM me
