08-24-2009 | #1 |
Waxers: step in; need advice
Black Z is beginning to get a number of swirl marks that detract from the sweet shine. Paint is generally good. I do not have a Porter Cable random polisher. Can someone please describe a step by step procedure to use to polish out swirls and and restore the finish with elbow power only ?! Thanks.
1991 ZR-1, Black, Black, # 541 |
08-24-2009 | #2 |
Re: Waxers: step in; need advice
its very tough to hand polish out swirls on blk paint .having a blk z i know .but that being said you could try using scratch ex by meguires. do a 2x2 sec use light pressure then seal with a poly seal by them also . a porter cable is to me a must for a blk car. if you get one buy some 3M ultra fina and the corisponding powderblue pad. use as directed on the bottle and you will have a great swirl free shine . you might also try signing on to the meguires site for help
08-24-2009 | #3 | |
08-24-2009 | #4 |
Check out the Zaino web site. I use this but I have a white car with no swirls
08-24-2009 | #5 | |
08-24-2009 | #6 |
Bob, you've got em but you can't see em !! White is the most forgiving color there is. Thanks for the tip.
08-24-2009 | #7 | |
Black, original paint and turned out fantastic. But I think all the waxes out there are "similar" and there is no best wax out there. One product I would recommend is "Adams brilliant spray". Great to use right before a car show and if you have black, you will LOVE IT. David |
08-24-2009 | #8 |
i would if i were you ,really think about investing in a porter cable and some pads from meguires . you could get all set up for about 250 and then at your leasure polish your car when ever you wish . also you might pm flynryan on this site his family used to own a detail shop .he is a really nice guy that allways willing to help .also there are vids on meguires that wilol help you to learn to do the polishing your self .
08-24-2009 | #9 |
Black? For heaven's sake...at least rent an orbital buffer!
I love the Zaino route, but there are several good regimes you can use. Check these two out...Nutting like black when it is "right".... My Z is red, but you can cannot see the swirls it once had after buffing it with a Porter Cable 7424 and Zaino's PC Fusion. But, unless you just have a butt load of elbow grease...get the PC. A terrific investment!! (OH! I lied...Zaino is not a wax) P.
08-25-2009 | #10 |
I wouldn't go the zanio route but i would check out http://autopia.org/
