08-23-2009 | #1 |
Proper PS procedure
Im finally getting my ish together and wanted to know the proper procedure for filling the power steering system after it has been completely emptied. Any help is greatly appreciated as I do not have a FSM. Thankyou.
IT IS THE FATE OF THE INNOCENT TO MEET WITH DEATH!!! |
08-23-2009 | #2 |
Re: Proper PS procedure
Here is what I did, I filled up the resivior started the car for few seconds and turned the wheel shut off the motor and topped off the resivior, started it again turned the wheel shut it off and checked the level if it needed more I added it then I test drove it and checked it again all you don't want to happen is cavitating that PS pump the air will work its way out.
But I can get you the FSM procedure if you want it.
08-24-2009 | #3 |
After doing what Phrogs posted, under advice from a pump vendor, at idle I rapidly cycled the steering lock to lock twenty times or so since this car doesn't see much street use. I put newspapers under the front tires since it was on slicks at the time.
Good luck, - Jeff PS here's a plug for Jeff at Turn One, their stock replacement ZR-1 pump seems to have cured my persistent issues. I'm even back to the stock cooler, which is a good thing since I was fixing for an argument on rules with the wacky setup I had in place. PPS, Turn One now has a nice aluminum pump for ZR-1, saves a few pounds and up high & in front to boot, great part but too bad I couldn't use it due to rules.
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
08-25-2009 | #4 | |
08-26-2009 | #5 |
http://www.turnone-steering.com/
They don't list LT5 on their catalog page but have definitely developed solutions for us, in either stock replacement or aluminum. Cheers, - Jeff
08-27-2009 | #6 |
Thankyou for the info. So the system purges itself of air? Seems easy enough.
