Old 08-07-2009   #1
Default What is the weight of a stock piston?
Does anyone know the actual weight of a stock, bare piston? The only information I could find was in Cor-vette specs book that says it is 1.4 lbs.
Thanks!
Old 08-07-2009   #2
tpepmeie
Default Re: What is the weight of a stock piston?
Average of 8: 486g, high 490/low 484g
this is on a 90MY engine.
Old 08-07-2009   #3
ZR1Vette
ZR1Vette's Avatar
Wow...quite a discrepancy between the numbers:
484g 1.067 lb
490g 1.080 lb
486g 1.071 lb
vs 'Corvette spec book' at 1.4 lbs
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 08-07-2009   #4
Thanks for the info; I really appreciate it. What else should I believe from this book if this info is so far off?
Old 08-07-2009   #5
484g 1.067 lb
490g 1.080 lb
486g 1.071 lb
Thanks. I was trying to compare the difference of some forged JE stock sized pistons that I have. These are 448g or 15.80 oz
Old 08-08-2009   #6
blackjack
the corvette spec book probably gives you the total weight of what is referred as a piston kit,: piston,rings,wrist pin and locks...they do that for balancing information
bj
91/1735
Old 08-09-2009   #7
bj
91/1735
Thanks, that makes sense.
