Old 08-03-2009   #1
Gary Yarbrough
Default Throttle Body Secondary Valves
At what point to the secondary throttle valves open?
I wish I didn't have to ask this because I know I've seen this information somewhere, but I can't seem to find it...
Gary Yarbrough is offline   Reply With Quote
Old 08-03-2009   #2
Hammer
Hammer's Avatar
Talking Re: Throttle Body Secondary Valves
Technically I don't know that answer either. But you should feel them open at around 3000 to 3500 RPM.
Old 08-03-2009   #3
bobbyhi
bobbyhi's Avatar
Default Re: Throttle Body Secondary Valves
I think it depends on the chip that is installed. Some of the tuners have different ranges for opening.
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 08-03-2009   #4
Depends on the RPM and the TPS% Opening set in the calibration. Not just one answer.
Old 08-03-2009   #5
Kb7tif
http://www.corvetteactioncenter.com/...diagnosis.html
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 08-03-2009   #6
Gary Yarbrough
Thank you! Figure 7 was exactly what I remembered seeing, I just couldn't remember where.
Old 08-04-2009   #7
Kb7tif
I wanted to see for myself when the big plates start to open so I pulled the intake hose so I could see right down the airhorn, put a mirror there so i could watch from the drivers position when i stepped on the gas.
The big plates crack open at about 15% throttle and go from there. So they open VERY quickey.
1992-Zr-1 Sold.
Watson Headers
Random tech cats
Fidanza Flywheel
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 08-04-2009   #8
You realize those aren't the secondaries we're discussing.
Old 08-04-2009   #9
Gary Yarbrough
Yeah, I didn't mean injector secondaries. I meant the larger valves on the throttle body. Mine seem to take a long time to open... I'm wondering if this could cause my hesitation...
Kb7tif, are you talking about the throttle body?
Old 08-04-2009   #10
Kb7tif
He mentioned picture#7 and that is the throttle body plates.
Another thing you can check is that are the plates on xfire is talking about, as just because the vacuum system is working and all does not mean that all 8 plates are opening. the Seconadry throttle linkage on these are somewhat flimsey and can break off. On My car only 1 of 4 were opening on one side.
To check this there is a wire on he c connector of the pcm you ground out 9I think its a purple one) and open the secondairy system with engine off.
Mark H's site expains this in detail on what wire and what connector.
The secondairy linkage is under the aluminum covers on each side. Kurt Has them. (thank god).
Its not worth pulling the plenum just for this but next time its off be worth a few minutes to check.
Marc H has a throttle body service he provides which he will check everything, this cures high idle is some cases and provides peace of mind. he can check if everything is aok. 165$ 3 day turn around send it in.
1992-Zr-1 Sold.
Watson Headers
Random tech cats
Fidanza Flywheel
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
