Old 07-29-2009   #1
Default Name that Noise>>
I have a vibrating type noise in my Z, as the car gets warmer or even sit for a short bit after being driven this noise gets a bit louder.
It was there last year, but I had a bent Water pump pulley and thought that was the issue and the tensioner was the noise..
in the video, the clank type noise is my applying pressure with a bar to the tensioner. I would like to determine the issue, although I am driving the car to Bowling Green next Friday..
I have put about 300-400 miles on this year and there are no issues otherwise
here is the link:
http://vettextc.jiminees.com/jeff/misc/0729091838a.mp4
Thoughts?
also let me know if the video does not work.. It works on my MAC and my VIsta machine.. might require Quicktime though
EDIT: I also thoght it might be the WP itself too, but it spun fine while the car was apart
Old 07-29-2009   #2
Sgreg
Sgreg's Avatar
Default Re: Name that Noise>>
here is the link:
Thoughts?
Do you have heat shields ? They tend to vibrate at a constant RPM when loose and they come loose easily. Wild guess.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 07-29-2009   #3
Heatshields on Exhaust?
just the ones on the body.. others are gone
This seems to be up front and with a high idle the noise changes the rhythm.
Starting to think Tensioner Pulley and probably worth swapping
Old 07-29-2009   #4
Jeffvette
Pulley issue.
Disconnect the belt, then start motor. No noise, replace belt as you now know it's on the pulley setup.
Lube tensioner pulley check for noise.
Lube alternator, check for noise.
Listen carefully at the power steering pump as well (Check fluid level)
Old 07-29-2009   #5
Pulley issue.
Lubed the Alternator.. no change
Need to check PS level..
thinking of buying a tensioner Pulley anyway (cheap part)
Thanks
Old 07-31-2009   #6
Idler pulley, but tensioner seems 'soft'
Old 08-01-2009   #7
jonszr1
jonszr1's Avatar
give it some viagra
Old 08-05-2009   #8
Idler Pulley fixed the howl
New tensioner fixed the vibration noise
All is good
Old 08-06-2009   #9
flyin ryan
flyin ryan's Avatar
Awesome
Old 08-06-2009   #10
secondchance
All is good
