Old 07-29-2009   #1
VetteMed
Default How to fix burned-through floorpan?
Background: 91 ZR-1, headers, no cats, straight pipes from headers back to mufflers - no resonator.
As I was gutting the interior from my 91, I found that the passenger side corner, where the floorpan meets the trans tunnel as it widens for the bellhousing, was burned by the exhaust, in approximately a 1" diameter circle. It was not burned entirely through, but all that remained was fiber strands, no hard substance at all. The carpet padding overlying it was completely disintegrated. I never smelled anything burning, so this may have happened when the previous owner had the exhaust done, I have no way of knowing.
So, what to do? Obviously I need to patch the hole, but more importantly, I suppose I need to fabricate a heat shield? Or do I just have a muffler shop bend the pipe a little?
What should I use to patch the floor pan?
Thanks!
Andrew
Old 07-29-2009   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: How to fix burned-through floorpan?
Sorry about the bad luck.
Can you post some pics?
Old 07-29-2009   #3
VetteMed
And in this one, you can see the offending pipe.
Old 07-29-2009   #4
Jagdpanzer
Jagdpanzer's Avatar
Pick up a fiberglass patch kit at your local auto or marine supply store, trim out the burned area and fix it like plugging a hole in a fiberglass boat hull.
Old 07-29-2009   #5
secondchance
Hole looks small enough (looks like about 1/2" hole?) where a temporary back up underneath with duct tape (attached to outside of car) and fill w/ epoxy mix. I think existing fiberglass strands would function to bridge the patch.
I would definitely rework the exhaust pipe to increase the distance to body. I have not looked carefully under this area while the car is on a lift so I am not sure. Does anyone know if there is a heat shield below?
Old 07-30-2009   #6
Jagdpanzer
Jagdpanzer's Avatar
The burned area is ajacent to the front exhaust spring hangers. There are no factory installed heat shields in this area as you find outboard the cats.
