Old 07-28-2009   #1
Default Pilot bearing puller
Anyone have the name of A Pilot bearing puller that works......
Thanks
Old 07-28-2009   #2
Jeffvette
Default Re: Pilot bearing puller
Any universal slide hammer set up should work.
Old 07-28-2009   #3
Wide_One
This is what I made up.....slide hammer from Napa Auto Parts interface slide hammer threads to puller fine threads bolt from general hardware and puller from auto zone. The puller forks will need a little custom filing.
Wide_One is offline   Reply With Quote
Old 07-28-2009   #4
Jagdpanzer
Jagdpanzer's Avatar
I used this puller from HF that worked perfect after first trying rental puller from Advanced Auto which broke a fork.
http://www.harborfreight.com/cpi/cta...emnumber=95987
Old 07-28-2009   #5
Wide_One
Even better!
Old 07-28-2009   #6
Toyvet1
Lee I have a basic one in the toolbox that Ive used on the Z a couple times if you need it. I work out of Barrington if your interested.
Toyvet1 is offline   Reply With Quote
Old 07-28-2009   #7
That Boetch is out! Used the blind puller...thanks for the advice everyone!
Best part is the Crank plug is in place and not moved at all
