07-23-2009 | #1 |
Crankshaft plug...
Well, I was not aware of the crankshaft plug until after I made several attempts to removal the pilot bearing. Needless to say I am alittle worried about the possibility of oil starvation now. I can see the plug is in place, but I am hearing the margin for error is 1/4".
1)any way to know if damage was done? Measurements, etc 2)replacement procedure?
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 07-23-2009 at 10:18 PM. |
07-23-2009 | #2 |
Re: Crankshaft plug...
Was thinking of measuring with a dial gauge on my spare crank and comparing to the one in the car.
07-23-2009 | #3 |
07-24-2009 | #4 |
Does the field service manual have the depth listed? It does for the LS6
07-24-2009 | #5 |
Spoke to Marc Haibeck, needs to be pushed in 1/2" before it interfers with oiling. I will pull the Pilot and check proper sealing
07-28-2009 | #6 |
Pulled the pilot..the plug is in place and no issues!
07-29-2009 | #7 |
Take a deep breath & say thanks .
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
07-29-2009 | #8 |
Replacement would not seem to be that hard, there is a stop to press it to....anyone done one of these.
NOT THAT I WANT TO FIND OUT!
07-29-2009 | #9 |
Ya'..just one of those thing that is better left undisturbed. If it moved even a tiny bit, then a guys worrying 'Will it Leak'? . Or if it does need to be changed on the car, did any of the original sealant manage to fall forward...another . It's no big deal to replace, most of the high end cranks I deal with are Rifle drilled same as the LT-5, but I'd much rather replace the plug with the crank on the bench, know what I mean buddy .
07-29-2009 | #10 |
Do you think I should put some epoxy around the edge to make sure it is still sealed?
