07-16-2009 | #1 |
Half Shaft Removal
Getting ready to pull my rust/dusty old steel half shafts....any words of wisdom besides "Lots of WD-40"? I am praying I don't break or strip any of the strap bolts trying to loosen them.
Rich
07-16-2009 | #2 |
Re: Half Shaft Removal
This is the way I do it:
http://personal.tmlp.com/scorp/vette...nts/index.html However, I believe it is easier to disconnect the spindle rod at the suspension knuckle rather than at the camber bolt as this guy shows. BTW I have several spare bolts and straps on hand in case you need them. Last edited by Jagdpanzer; 07-16-2009 at 01:58 PM. Reason: Added removing spare tire carrier |
07-16-2009 | #3 | |
Rich
07-16-2009 | #4 | |
The straps and bolts can be re-used. A wire wheel takes care of everything on there. Make sure you use a dab of loctite when putting the bolts back in. I do remove the knuckle as well when doing work like this. Just makes the whole job easier. |
07-18-2009 | #5 |
Well, got drivers side done...only took me 6 hours . Now that I kind of know what I'm doing, hopefully, the passenger side goes a little faster.
Rich
07-19-2009 | #6 |
Well, got the shafts swapped. Not too difficult once you get the hang of it. A pic of what came out of the Z and what went back in...what a difference.
Rich
07-19-2009 | #7 |
Any idea of the weight savings?
07-19-2009 | #8 |
No, didn't take the time to weight them(guess I should have), but my guess would be 5-10 lbs per shaft. Those steel shafts were HEAVY compareed to their aluminum counterparts.
07-19-2009 | #9 |
Good job Rich. That is a great improvement.
