Old 07-09-2009   #1
VetteMed
Default Floaty ride?
Now that my Z is up and running, I've noticed that the ride seems rather floaty compared to my '94 C4 (LT1, with base FE1 suspension). It seems like I get quite a bit of bounce after relatively gentle highway dips... And it doesn't seem like changing the FX3 setting does very much. I occasionally get a "Service Ride Control" light upon startup.
EDIT: I just found the procedure to pull the FX3 codes, so I'll do that tonight and post my findings.
Sound like the bilsteins need a rebuild/revalving?
BTW, the car has 65K miles, and sat for approx 2 years before I bought it.
Old 07-09-2009   #2
Default Re: Floaty ride?
Well the fronts can be had on Ebay for $183 the rears youll have to pay full boat. I dont recommend revalving as a total rebuild is over $120 each and unless your going with a Morraco valve setting and planning on Autocrossing the car its simply better to buy new. A member a while back went through the process and was Low balled on the revavling job and he received his old nasty looking revalved shocks back He said crap he had to paint them before he put them back on the car. End result for an extra $30 each shock could have been new. Just some thoughts GC
Old 07-09-2009   #3
Kb7tif
Have the shocks revalved to morrocco valving at the factory. Have heard some positive comments. on the results
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 07-09-2009   #4
I was going to go the re-valve route. but I got the eBay deal on the fronts.. I still need the rears, but I have a complete set off the car right now too.. Those I was going to send in for a re-valve.. but might just buy 2 new ones for the rear.
I would not mind the modded controller though as i thought at one time there were different PROMs for the controller
Old 07-09-2009   #5
Kb7tif
Is there any place that shows info
on that controller setup? I need something like that for launches
1992-Zr-1 Sold.
Watson Headers
Random tech cats
Fidanza Flywheel
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 07-09-2009   #6
I would say call Bilstein.. they may still have them
Old 07-09-2009   #7
eshocks.com has FX3 for $179.75 ea front and rear..
better then the 183.xx Ea on eBay
Old 07-10-2009   #8
Aurora40
Aurora40's Avatar
I found Summit racing had them even cheaper than eshocks. And I feel a bit better buying from Summit. Though they were not "in stock".
FYI to the OP, if changing from "tour" to "perf" doesn't feel like anything happens, something is wrong. Sport and Perf feel somewhat similar, but tour and perf are quite different to my butt.
Bob Saveland
Former owner of #2517
Old 07-10-2009   #9
Same price now basically 179.95 @ Summit and I agree I would buy from summit before eshocks
As for the controller, I agree, Touring to Perf is a noticeable difference
Old 07-10-2009   #10
VetteMed
Now that I think about it, I don't recall switching to Perf, just stayed between tour and sport. Next time out, I'll try Perf for comparison.
