Old 06-09-2009   #1
jonszr1
jonszr1's Avatar
Default coilover sprind adjust tool where .....
can i get one .at a reasonable price / are they all the same or do i need some dimensions? can anyone help me out .thanx for any help
Old 06-10-2009   #2
Default Re: coilover sprind adjust tool where .....
spanner wrench??
I got mine at Speedway Motors for around $10
Old 06-10-2009   #3
WVZR-1
If your coil-over nuts have just tangs/notches then most any will do. The one -=Jeff=- mentions is quite inexpensive and should do. If they're just round nuts with drilled holes you might want a specialty one to keep from destroying the finish.
I had some early Carrera that used the round drilled nuts. The spanner that I have for the QA-1's I've got wouldn't catch them. The hook was to large. If you've round drilled nuts you want a Joe's Spanner with a round pin!
