Old 05-04-2009   #1
Default Car hit 7MPH in the superwash today but I was not moving
Just curious as to why the car speedo was reading MPH while the car was sitting still in the car wash.......speedo hit 7 MPH. I assume the water was the culprit....but should it do that?
Old 05-05-2009   #2
rhipsher
rhipsher's Avatar
Default Re: Car hit 7MPH in the superwash today but I was not moving
Thats a new one. I only take it to the stalls where you park and spray them off and use the foam brush.
Old 05-05-2009   #3
That is a bit odd. If it was water then maybe the connector at the VSS is loose? Or lost the rubber gasket? You were spraying water up under the car to clean the bottom?
Ever notice it doing that when driving in the rain?
Old 05-05-2009   #4
This is a touchless with an Arm that circles the car.
