03-24-2009 | #1 |
Adam's Daily Special! (Updated Daily)
Adam's GREEN Cleaner Gallon with FREE 16oz Undercarriage Spray!! Adam's Daily Special! For a limited time we'll include a FREE 16oz Undercarriage Spray with a purchase of a Gallon of Adam's GREEN Wheel Cleaner! Our 'Eco-Friendly' wheel cleaner is tough on dirt, gentle on your wheels, and easy on the environment. It's a true, blue American solution to a green problem! Adam's GREEN Wheel Cleaner is a 100% water-based cleaner that safely and effectively cleans tires and all types of wheels! Adam's GREEN Wheel Cleaner takes advantage of new breakthroughs in chemical engineering, creating a new class of non-ionic cleaner that does not release harmful zwitterions. Adam's GREEN Wheel Cleaner quickly and safely cleans tires and all types of wheels including clear coated, painted, aluminum, polished and anodized. The active ingredient in this cleaner was developed in America to replace the acids, butyl and butyl ethers found in most tire and wheel cleaning products, which have been proven harmful to both wheels and nature. It's an unfortunate fact that most wheel cleaners made and sold in America contain butyl or butyl ether. Although butyl is a highly effective cleaner, as well as inexpensive, it is harmful to man and the environment. Plus, butyl will white-stain aluminum and damage clear coated wheels and powder coating finishes. Butyl is also very harsh on your skin, causes respiratory distress when inhaled, and it is not readily biodegradable. Adam's GREEN Wheel Cleaner contains no butyl or petroleum distillates! Plus, our new GREEN Wheel Cleaner biodegrades 98% in less than 24 hours, protecting our surface waters from polluted storm drain runoff. Adam's GREEN Wheel Cleaner is a 100% water-based cleaner! It contains no no petroleum distillates, no acids, and no butyl of any kind. It is 100% safe for use on tires and all wheel finishes including polished aluminum and clear coats. With light agitation, Adam's GREEN Wheel Cleaner quickly and safely removes all dirt, road oils, and brake dust without harming you wheels, the environment or you!. Adam's GREEN Wheel Cleaner is not a spray-on, hose-off cleaner. Our GREEN Wheel Cleaner requires agitation with a brush, sponge or wash mitt to break the initial bond between the dirt and the wheel. Spray-on, hose-off type wheel cleaners are harsh, acid based cleaners that damage wheels over time. Adam's GREEN Wheel Cleaner will never harm your wheels or the environment! Last edited by Jason@Adams; 04-28-2009 at 01:17 PM. |
03-25-2009 | #2 |
Re: Adam's Daily Special: 3/24 2 Buttery Wax +1 Free!
Updated for today!
03-26-2009 | #3 |
Updated for 3/26!
03-27-2009 | #4 |
Updated for 3/27!
03-30-2009 | #5 |
Updated for 3/30!
03-31-2009 | #6 |
Updated for 3/28!
04-01-2009 | #7 |
All set for 4/1!
04-02-2009 | #8 |
Updated for 4/2 and don't forget your instant savings code!
04-06-2009 | #9 |
Updated for 4/6 and don't forget your instant savings code!
04-07-2009 | #10 |
Updated for 4/7!
