Old 03-21-2009   #1
IowaZR-1
IowaZR-1's Avatar
Default tire pressure sensors question
Was getting new tires mounted last weekend and broke a band on the pressure sensors(Left Front) on my '93. I have a band coming, my guestion is.....are the sensors directional? There's an ">" on it but nothing else saying rotation or such. I've seen that on the earlier ones 1988-92(black box) there is a rotation arrow but nothing on the newer 1993-96(white box).
Thanks!
IowaZR-1 is offline   Reply With Quote
Old 03-21-2009   #2
Default Re: tire pressure sensors question
THe > IS the directional arrow of rotation on the black bodied sensors as well. However a word of caution the bands are the same but the counterbalances are indeed different. Make sure you use the same counterbalance weight that came with your old unit or it matches the unit your are replacing if its coming with the new band. The sensors changed body styles when the white pyramid styles came onto the scene vs the black boxes. Just a thought from your friendly cylon
Old 03-21-2009   #3
1990 415
by your command.
1990 415 is offline   Reply With Quote
