Old 03-16-2009   #1
Scrrem
Scrrem's Avatar
Default Seat Switch...
Is it possible to switch the driver and passenger seats. I have some wear marks starting on the drivers seat from the previous owner. I would like to even out the wear a bit. If so, is it easier to switch the cusions or unbold the entire seat?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 03-16-2009   #2
jonszr1
jonszr1's Avatar
Default Re: Seat Switch...
yes , alot of us have done it .its not hard at all will take you about an hr. 4 bolts and 3 connecters on each seat and poof you have a nice drivers seat. too bad the aftermarket only sells the seat covers in pairs .
Old 03-16-2009   #3
Scrrem
Scrrem's Avatar
Cool, at a glance, it looked pretty straight forward. I just wanted to make sure GM didn't want to make thing interesting by making different electrical connectors between driver and passenger seats You know these engineers!
Thanks
Rich
Ron Davis Radiator
Old 03-16-2009   #4
xlr8nflorida
xlr8nflorida's Avatar
Can't you just take the seat cushions out and swap them, should take 15 minutes max?
Old 03-16-2009   #5
jonszr1
jonszr1's Avatar
he may have an upper bolster wear deal that he want to get rid of .
Old 03-16-2009   #6
Scrrem
Scrrem's Avatar
Exactly right. With all the air mechanisms, I figured I would do less damage and just swap the enire seat....in theory
Rich
Ron Davis Radiator
Old 03-17-2009   #7
secondchance
For 94 and 95 it's pretty easy.
I figure similar for 90-93.
For my 94, I pulled both seats, removed and changed seat backs at the hinge and swapped bottom pieces. Bottom piece foam is slightly different contour so had to slice off a piece and transfer to the opposite side with double stick tape.
Old 03-17-2009   #8
Norsky4360
Good to know. I may do the swap b4 the driving season arrives. I know the current right seat has had less use than the left.
[IMG]http://www.c3vr.com/member_uploads/401_500/419/thorsten_norge.gif[/IMG] [B][I]Jim O. [COLOR=white]..............[/COLOR][IMG]http://www.c3vr.com/forum/smileys/smiley27.gif[/IMG] [IMG]http://www.c3vr.com/member_uploads/401_500/419/driving1.gif[/IMG] "[COLOR=red]The Toys[/COLOR]" [/I][/B]
...'90 ZR-1.......'70 roadster.......'78 Trans Am....
[I][B][URL="http://www.c3vr.com/member_uploads/401_500/419/TheToyII_102_852.jpg"][IMG]http://www.c3vr.com/member_uploads/401_500/419/TheToyII_104_65.jpg[/IMG][/URL] [URL="http://www.c3vr.com/member_uploads/401_500/419/TheToy.jpg"][IMG]http://www.c3vr.com/member_uploads/401_500/419/Itsa70_36a2.jpg[/IMG][/URL] [URL="http://www.c3vr.com/member_uploads/401_500/419/PICT3106a.JPG"][IMG]http://www.c3vr.com/member_uploads/401_500/419/PICT3106a_sig.JPG[/IMG][/URL] [/B][/I]
(click on each to see a larger version)
[I][B][COLOR=red]Save the Wave...!!! [IMG]http://www.c3vr.com/images/smilesani/wavey.gif[/IMG][/COLOR][/B][/I]
Norsky4360 is offline   Reply With Quote
