Old 03-10-2009   #1
Angry Emissions retest another failure
Ok fellas WTF is going on
1st Failed test with a bad drivers side factory Cat and DRM chip
Standards are 1.00 for HC
12.00 for CO
2.50 for NOX
Results
HC: 1.51 Fail
CO 8.38 Pass
NOX 2.71 Fail
2nd test with Jeal headers with Magnaflow cats and DRM chip
HC: 2.34 Fail even worse now
CO 8.86 Pass
NOX 2.54 Fail
Is it because of DRMs chip and mods? I still have the factory prom. What does the group think? Help
Old 03-10-2009   #2
Default Re: Emissions retest another failure
These metallic substrate cats do not get hot enough, long enough to do the proper job. That is the rub with these low restriction hi-perf cats.
Ron Kreigh, uses alcohol and gets the car to 230* on the water temp and he passes.
I would try the stock PROM, just for the emission test. Get the water temp waaaaay up there so you know the cats are hot. Maybe even do a temp header wrap on the cats to hold the heat in?
I had asked Mr. Haibeck about having the cats coated also to keep the heat in them, but he said that he didn't think that was a good idea. S/S disperses heat too quickly, that's one of the reasons professional chief's do not like to cook with it.
p.s.: thanks for not being sore at me for posting the corvette recycling thing!
Old 03-10-2009   #3
What kind of alcohol? Should I unplug the fans to get the water temp up a never see above 60% of band since I replaced the radiator.
Old 03-10-2009   #4
jonszr1
jonszr1's Avatar
i agree with putting the stk prom in and getting her hot just before you go there . another thing you might consider is doing the seafoam thru the brake booster line . i did this to my white car and couldnt believe the junk that came out of the exhaust. also i have heard that changing the oil just before going helps .wish i had more ideas but where i am at we only have to smog cars when we buy or sell them
Old 03-10-2009   #5
jonszr1
jonszr1's Avatar
also if its needed i could send you the extra set of stk manifolds and cats for you to pass. i would send them for free just to help out . just let me know if its a need .another idea is maybe we could cut off my cats from the manifolds and adapt them to your exhaust .
Old 03-10-2009   #6
I never asked him, but I would figure it would have to be the same as the stuff they put in the gas, ethanol, right? or is it methanol? Chit I can't even remember what's on the friggin gas pump.
Maybe just throw in a big bottle of Techron fuel treatment?
Fans, hummmm that is a problem. My first thought would be to block off some of the air flow using a small piece of cardboard slipped up in front of the A/C condensor...like the over the road truckers use those leather covers on the front of the radiator grill? Turning off the fans plural maybe dicey, maybe unplug the secondary fan might be a way to get the temps up towards the last 1/4" of the gauge where it's supposed to be 230* + ???
Clean plugs w/tight gap 0.35", clean air filter, clean PCV's, stock PROM, and hot water...then try & sniff it to see how close ya get. If no good, I'd try the header wrap on the cats & collectors and some of the piping leaving the cats.
Sorry Daryl, I'm not much help....go ask Jeff, he will know! You do have the A.I.R. system connected, right? Not sure if it makes a difference.
Old 03-10-2009   #7
Okay, taking a deep breath and thinking out loud.....the stock PROM's fueling is rich. I get that from Mr. Haibeck's web site, if I understand what I was reading....
His Hi-performance chip pulls fuel out, I thought, but for headers he puts more fuel back in....I think again if I get this stuff which is doubtful.
The bottom line is a ceramic grid cat gets waaaaay hotter than a s/s metallic web type cat. If the cats don't get hot, then they can't do their job. Also, the grid or honeycomb cat presents a longer route for the exhaust gas to take to get out, therefore it gets treated more. The s/s cats let the stuff out too fast, so it's dirty. The reaction relys on the temp of the catalyst, which is a function of how long the exhaust gas stays in the cat. A higher water temp may translate into richer fueling?, to prevent detonation?, the richer fueling may provide enough heat for the cats to work at idle??? I really think that it comes down to how much heat can be kept in the cats, JMHO after all this out loud thinking.
Old 03-10-2009   #8
AIR system is disconnected as I was told its only function was to preheat the cats for about 5 mins before start up which is why we all hear that pump motor noise before startup. Im putting the stock 91 PROM back in which I think might resolve the NOX issue but im not so sure on the HC as its more than 50% worse than the stock cat. Wrapping may be a solution as well as denatured alcohol according to Jeff. I really dont want to hang the old cats backinto the system as the only option you have is used cats. Thanks for the ideas guys keep them coming.
Old 03-10-2009   #9
I changed the oil this week as well.
Old 03-10-2009   #10
jonszr1
jonszr1's Avatar
i do think the stk prom might help. summit sells that heat wrap. for 50 bucks i think you could wrap them both .
