02-04-2009 | #1 |
Ignition channels
So, I'm installing the MSD DIS-4 on the car, but I need to know which channel is which.
Does anybody know if channel 1 is coil 1 and so on, as listed in the FSM? Does it matter? KT
1990 Grey/Black Too many for the sig. |
02-04-2009 | #2 |
Re: Ignition channels
I don't know if this will help. I looked in the electrical section 8A book and this is what I found:
Coil 1 = 1 yellow ckt 933 Coil 2 = 1 Dk Green ckt 934 Coil 3 = 1 Dk blue ckt 932 Coil 4 = 1 Orange ckt 926 The above are wires going from the "Distributorless Ingition Module", but where they are going to is where i get lost as I sure don't understand how to read the diagrams...sorry.
02-04-2009 | #3 |
Not sure what you mean by "channels" and I'm not familiar with MSD DIS-4,
but our ignition system is "waste spark". Pairs of cylinders are fired, ie 1-6. The FSM will show the pairing. |
02-04-2009 | #4 | |
just looked at the User instructions for the DIS-4.. It does not seem to matter on the correlation of Channels to Coils.. BUT be sure the matching input and out put wires are used on the same coil. So now I have to pose the question, what is the reasoning behind adding the MSD? you looking for improvement of sorts or??
02-04-2009 | #5 |
The instructions seem to indicate the MSD unit between the PCM and the coils. I am assuming in the case of the LT5 that means between the Ignition Module and the coils.
I'll second Jeff's question on the need for the MSD unit. I'm not being skeptical, just curious. |
02-04-2009 | #6 |
Correct between Ignition Module and Coils
02-04-2009 | #7 | |
As far as reasoning, two words: future improvements.
02-04-2009 | #8 |
And actually with the coils adaptors from MSD, no wires have to be cut in the factory loom to install the MSD unit. I can take it out any time I like.
02-04-2009 | #9 | |
But I didn't know if coils related to channels directly in the MSD unit.
02-04-2009 | #10 | ||
Yeah, that MSD has soem nice features to go along with it.. Please post pictures when you tackle the install..
