02-01-2009 | #1 |
Code 64
Is Code 64 a lean right bank?
This is on a 1990.
02-01-2009 | #2 |
Re: Code 64
Looks to me like a bad O2 or bad ground on the O2, does that sound correct?
02-01-2009 | #3 |
Re: Code 64
Code 64 is a Lean O2 sensor reading. What was happening when the code set? The ECM was seeing a too low O2 sensor reading for at least 2 sec.
I would change the O2 sensors anyway but wouldn't count on the fact that its a defective O2 sensor. |
02-01-2009 | #4 |
Re: Code 64
Went on while cruising.....not hard accel or anything. Car ran fine.
02-01-2009 | #5 |
Re: Code 64
02-02-2009 | #6 | |
Re: Code 64
My AutoXRay scanner sorted it out very quickly. You can get a bird's eye view of the cross counts and the range averages for both sides. It's available, if you want to use it. P. |
