Old 01-11-2009   #1
ZR1Vette
ZR1Vette's Avatar
Default ID for couple items>>>
In the amidst of my winter projects and while having the left wheel well rear housing removed these two items are attached to the inside of the housing.. one is a plug with a cover and the other looks to be a module of some sort.. any one ID what they are?
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 01-11-2009   #2
rebelz
rebelz's Avatar
Default Re: ID for couple items>>>
I believe the one toward the front (left in the picture) is the Vacuum pump fuse and holder. I haven't figured out the other one. Anyone? Anyone? Bueller?
REBelZ
'92 ZR-1 Yellow/Black #031
rebelz is offline   Reply With Quote
Old 01-11-2009   #3
I'm not 100% sure on the larger rectangle like box, but I do think that on our 90 Z's it's one of the "Quad Driver" boxes for the fuel injectors.
There are two of those, one for the 1* and one for the 2* injectors. Oh, I do believe that they are NLA, so be nice to them!
Old 01-11-2009   #4
ZR1Vette
ZR1Vette's Avatar
Tom...bingo...once you suggested the ID I went to the shop manaul and right on (item in pic is what is #1 in this graphic)>>
Michael
:cheers:
Old 01-11-2009   #5
RICKYRJ1
RICKYRJ1's Avatar
OK Sherlock! Where's Jimmy Hoffa???
Old 01-12-2009   #6
ZR1Vette
ZR1Vette's Avatar
Also for the quick of eye... the VIN is stamped on the frame rail in the right of the picture...another way to verify car authenticity.
Michael
:cheers:
Old 01-12-2009   #7
ZR1Vette
ZR1Vette's Avatar
And rebelz gets the kudos for the ID of the In-Line Vacuum Pump Fuse 10 amp...finally found it in the Electrical Diagnosis Service Manual Supplement>
Michael
:cheers:
Old 01-12-2009   #8
Aurora40
Aurora40's Avatar
Just FYI, I believe they are actually both for the secondary injectors. Each one controls four injectors.
Bob Saveland
Former owner of #2517
Old 01-12-2009   #9
Yes, my bad....it's been so long since I looked in that section of the FSM. I remember doing all that looking in prep for me doing my 1st plenum pull. I was looking at everything associated with the FI system. noooobies!
I was sooo apprehensive when my 1*'s quit!
Ya I know so what was I doing down there...finding a suitable place for my hood light shut off switch.
Old 01-12-2009   #10
Oh, didn't the real estate agent tell ya?? Under your garage floor...waaaay under the floor.
